Light Weight Valves?
Old Aug 12, 2002 | 04:18 PM
topfig1's Avatar
Default Light Weight Valves?
Who makes them in 2.02 & 1.57 and where can I get them? Thanks for your help in advance.
topfig
MGySgt USMC
Old Aug 12, 2002 | 07:41 PM
xssive's Avatar
Default Re: Light Weight Valves?
Ferrea makes em but they are like 100 bucks a piece. Not worth it!
Old Aug 12, 2002 | 08:56 PM
2000 Camaro SS's Avatar
Ferrea makes them (I have them) $16.50 a peice. I had to have the shop that did the heads order them. They are the Ferrea Comp + Valves these are the only ones that you can get from Ferra in those sizes that fit in the stock heads.
Old Aug 13, 2002 | 04:44 PM
topfig1's Avatar
Thanks for the heads up guy's.
topfig
MGySgt USMC
Old Aug 13, 2002 | 05:04 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
May also want to ask Craig at GTP, he's a guru for this stuff:
713.266.1320
Also, lightweight valves are useful for example to mitigate valve float from high revving combo's... S/E cars use titanium valves and other high revving cars do too.
Old Aug 16, 2002 | 06:47 AM
Matt98SS's Avatar
Del West makes some nice titanium valves. I am sure they could make you a set to your specs. I wouldn't consider justifying the cost unless you were going to a solid roller that you wanted to really rev say 8000 or higher.
