X1 cam and 383 dyno
Old Aug 13, 2002 | 03:25 AM
RUF SS's Avatar
Default X1 cam and 383 dyno
446 rwhp
447 rwtq
MTI said I should change the Led and see about 8 rwhp more!
But the TQ is very nice!
<img src="http://acad.stedwards.edu/~talqatt/Dyno383LS1.gif" alt=" - " />
Old Aug 13, 2002 | 03:29 AM
RUF SS's Avatar
Default Re: X1 cam and 383 dyno
My mods are in sig!
Old Aug 13, 2002 | 04:17 AM
Damian's Avatar
LSX Mechanic
Not to bad for a mild setup. That cam is actually somewhat small in the bigger motors. Some GTP ported LS6 heads and a bigger cam would put you up about 20-25 rwhp. What compression are you running?
When you said "led" do you mean air lid?
<small>[ August 13, 2002, 04:19 AM: Message edited by: Damian ]</small>
Old Aug 13, 2002 | 07:49 AM
onfire's Avatar
Coal Mining Director
Great Numbers out of a stroker....is the 412 rwhp curve the 226 cam? Please explain the 3 graphs...TIA. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Aug 13, 2002 | 08:16 AM
LEO's Avatar
LEO
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Damian:
<strong>Not to bad for a mild setup. That cam is actually somewhat small in the bigger motors. Some GTP ported LS6 heads and a bigger cam would put you up about 20-25 rwhp. What compression are you running?
When you said "led" do you mean air lid?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe he would achieve more hp just by going to a bigger cam and LS6 heads, MTI has more then proven its porting ablities. I know a friend of mine with their 382 all-bore set up that makes 470-480 rwhp.
Old Aug 13, 2002 | 08:23 AM
383ss's Avatar
so you're not running a cut-out, ported TB, or ported MAF/Ends either?? What about !cats??
if so those are amazing numbers, nice numbers anyway!!!
<small>[ August 13, 2002, 10:26 AM: Message edited by: 383ss ]</small>
Old Aug 13, 2002 | 09:10 AM
Fenris Ulf's Avatar
What is the cam compared to in that dyno? You have a lunati 383 but no LID??? You have an easy 25+ rwhp in boltons and free mods!
Old Aug 13, 2002 | 09:40 AM
CHRISPY's Avatar
He is running a stroker not an all bore. The all bores will make more power due to the 4.1+ bore vs 3.905 for the stroker.
I think the numbers are great and that cam is very mild for that package.
If you do not have a lid on the car you will get another 20+RWHP no problem.
If I were throwing a 4.0-4.125 stroker crank in my car I would go 236/230 112LSA .60x lift minimum reverse split.
Great numbers!
Chris
Old Aug 13, 2002 | 09:48 AM
HP-GURU's Avatar
Nice power for a short powerband. Torque comes up
quick and hard.
Old Aug 13, 2002 | 09:56 AM
VINCE's Avatar
Shorty Director
Your setup is strong..
Old Aug 13, 2002 | 01:08 PM
383ss's Avatar
WOW, nice numbers with the mods and a stock air lid!!!
And NO CUT OUT!!!! that would probably add about 10+rwhp!!
I think you could easily be sitting at 470+RWHP.
Curious why you are running a stock MAF (with the screen too??) I believe LS1 edit should solve any issues with that.
Old Aug 13, 2002 | 04:09 PM
RUF SS's Avatar
383ss,
I have the K&N FIPK intake!
Old Aug 14, 2002 | 12:15 AM
RUF SS's Avatar
Ok, I wanted a daily driver with no drivability issues at all. The car idle very good with no stall problems at all. In fact, if it had the cats on, it will be hard to notice the cam.
The bottom graph (412 rwhp and 404 rwtq) the car was not running very good. the max we were able to get from it was 412 rwhp with 6 dyno tunings.
The mods were:
*No cats
*2.5" y-pipe
*FLP headers
*226.5/226.5 114 LSA
*K&N FIPK
*LS6 intake
*ARE heads (they did not flow very well, because they had 2.1x intake valves and I ordered 2.08 <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> )
*Stock MAF
*ASP pulley
*MTI tuning
*ATR cat-back
*SLP 4 tips in the middle thing! (Probably lost 4 rwhp).
Ok, the middle graph (439 rwhp and 435 rwtq) This is after the installing the X1 cam. Also, MTI changed the valves to 2.08 and stock lengths and 7.400 pushrods. ARE use some weird valves lengths which makes the pushrods 7.250 long (very short).
The mods were:
*As above +
*3" y-pipe
*X1 cam
The top graph (446 rwhp and 447 rwhp)
After tuning we got this result!
We did not spend much time on tuning. I think there is about 5-10 rwhp more if I played with LS1-edit a bit more. I could probably install a batter MAF, Put the whisper lid style air induction on (as been told by MTI, the Whisper lid style lids will have better power (about 5 rwhp more) than the FIPK).
*As above +
*Tuning
There you have it!!
I am very happy with the car. It picks up like a bullet!
Yeah, and get this, when I left MTI a ricer Civic pulls next to me a start riving his engine!
What can you say! I was hungry and my SS was too! Therefore we had some rice! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ August 13, 2002, 12:18 PM: Message edited by: RUF SS ]</small>
