Is this too much???
Old Aug 15, 2002 | 12:09 AM
Carlos's Avatar
Default Is this too much???
I have a '98 Vette A4 and am going to get a cam put in next week. The tuner recommended a cam with the following specs:
230/226 .591/.569 112 LSA
I am going to get the PCM reprogrammed by Ed Wright...do you think I should stick to a 114 LSA or would the 112 be ok to go with if I have my PCM programmed? Would this idle very rough/lumpy? Given it's going to idle lumpy, but would it be irritatingly lumpy? By the way this is a daily driver.
Oh one more question, would this cam pass emissions in TX?
<small>[ August 15, 2002, 12:11 AM: Message edited by: Carlos ]</small>
Old Aug 15, 2002 | 12:16 AM
VINCE's Avatar
Shorty Director
Default Re: Is this too much???
Nice cam.. It should work fine. However, I would do ls1edit..
Old Aug 15, 2002 | 02:28 AM
AlonzoVersion 1.0's Avatar
It will pass so long as your car doesnt throw any codes.
Old Aug 15, 2002 | 08:18 AM
Carlos's Avatar
So just as long as all the bugs are worked out by the programming I should be ok then...with the AC, idle, and emissions? I will be leaving in about an hour to go put a down payment on the stuff so I need yalls opinion QUICK!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ August 15, 2002, 08:20 AM: Message edited by: Carlos ]</small>
Old Aug 15, 2002 | 09:12 AM
CHRISPY's Avatar
You wont pass emissions with the cam.
I would go 224/224 114LSA TOPS if you are worried about emissions.
Cheers,
Chris
Old Aug 15, 2002 | 09:53 AM
Fenris Ulf's Avatar
If you arent having Ed tune the car on his dyno, don't bother. I have seen lots of bad tunes come through the mail.
That cam should idle just fine, im sure it could pass emmissions if you had a pair of good cats and the car was running properly.
Old Aug 15, 2002 | 11:13 AM
DERTY's Avatar
The Bull
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fenris Ulf:
<strong>If you arent having Ed tune the car on his dyno, don't bother. I have seen lots of bad tunes come through the mail.
That cam should idle just fine, im sure it could pass emmissions if you had a pair of good cats and the car was running properly.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No kidding. The best tune jobs don't come mail order all the time. Nothing against Ed Wright, he has a lot of satisfied customers from what I can tell. But, assuming everything on your car is perfect the tuning should be fine. However if I had mail order tuning for mine I still would have been leaner then hell and we would have never known. Get a dyno tune if it means that much to you. I ultimately had to get bigger injectors to handle the extra fuel needed. Just my $.02 worth.
