How to check valvespring installed height?
If I can get the parts before Saturday, one head will be done while off the engine, and the other while on...else both while on.
Thanks!
You need a spring height checking tool. Call American Motorsports and see if they have one. You might need shims if the installed height is too tall.
What springs do you have?
<strong>I have the 26918's. Pete says the installed height needs to be in the range 1.825 <-> 1.835. I bought a valvspring micrometer, but don't know what else I need or the procedure...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You should set them up tighter than that. Shoot for around 130lb of seat pressure. This will require ~ 1.78" installed height.
Jason
Mueller!.....Mueller!..... <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
My cam: 218/226 527/535 112LSA.
All this is null'n'void if someone doesn't tell me how to do it <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
