No Oil Pressure
What else could I check?
Also is there a way I can check if I have oil pressure by my A Tap?
TIA
ALbert
Mine died 3 weeks ago and I'm in the process of figuring out just what I'm going to do. I may have spun a bearing, need to look.
did you install the metal gally plug in the front pasenger side of the block behind the timing chain cover??
i had that same problem when i put mine together.
<strong>did yo uinstall the plastic gally plug in the rear of the motor ( behind the rear cover)??
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats what it was. The guy that built my motor told me he installed it and didnt. I went ahead and checked it and it was missing.
i almost started the engine and let it idle till i see oil pressure! not very smart!
some one said that you still get pressure to the bearings but not the oil gallies... not sure though.
<strong>It only ran for 5 or 10 sec.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's a good idea to unplug the coil packs and crank the car untill you see oil pressure on a new motor. It takes a little while.
just crank it for 15 sec. more than enough!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What are these plugs? and when would they be removed?
