382 with supercharger what cam to use
Old Aug 21, 2002 | 12:22 AM
2bseen's Avatar
11 Second Truck Club
Default 382 with supercharger what cam to use
I have a 382 lunati short block with stage 2 heads flows 283 at 500, vortech supercharger 8# boost, flp headers, ls6 intake, I have a 221/221 558/558 114 cam is this as good as I can get I think it is too small please give info and advise.
thanks tony
Old Aug 21, 2002 | 04:20 AM
AlonzoVersion 1.0's Avatar
Default Re: 382 with supercharger what cam to use
Its very small and I am not sure about duration or lift but make sure to get whatever cam you get on a 116 lsa as it will hold more boost in the cylinders longer.Oh and get a reverse split with more exhaust than intake duration.
Old Aug 21, 2002 | 08:15 AM
JPR's Avatar
JPR
A good cam would be in the 220 range, your 221 on a 114 is fine too, don't worry too much about the intake flow values, just make sure the flow is there at your cam lift. Most importantly would be a very efficient exhaust flow.
Good Luck! sounds good.
Old Aug 21, 2002 | 08:30 AM
dug's Avatar
dug
comp XER 240 single pattern with 114 degree centerline and straight up.
Old Aug 22, 2002 | 09:56 AM
2bseen's Avatar
thanks I was thinking maybe a reverse split also
Old Aug 22, 2002 | 11:42 AM
CHRISPY's Avatar
230/236 on 114LSA and an aggressive lobe like the XE-R. Will make great power and be pretty tame with the extra cubes.
Peak power will likely be in the 6500rpm range depending on exhaust configuration. I would also consider full length 1 3/4 headers and a 3 inch Ypipe with dual cutouts and 3 inch int pipe.
Cheers,
Chris
Old Aug 22, 2002 | 04:24 PM
2bseen's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>230/236 on 114LSA and an aggressive lobe like the XE-R. Will make great power and be pretty tame with the extra cubes.
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have full length headers and a 3 inch y pipe I need the peak power to be in the 5800 to 6k range b/c I am max rpm on the vortech at 6500 rpms also I am installing dual cutouts on the y pipe.
thanks tony
Old Aug 22, 2002 | 07:35 PM
cablebandit's Avatar
I think your combo is perfect for the 6400 rpm limit imposed by the S/C. Besides, if you get something else, I'll have to help you work on that **** <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Aug 22, 2002 | 07:44 PM
Gary98Z's Avatar
That's a nice setup you have. Just curious...what kind of power/times you putting down?
Old Aug 23, 2002 | 12:00 AM
2bseen's Avatar
cable is scared is why he doesn't want to work on my ****. Times coming soon.
