Timing Set Replacement Question.
I will also be putting in NGK TR55's when I do the swap. They are gapped at .050 currently. Is this where I want them to be at?
Thanks In Advance.
<strong>I used a standard "hook" type puller to grab it right behind the teeth.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">like the same puller to pull the crank pulley off with?
tape the new one on with a brass drift or a piece of wood if your willing.
its keyed and will go on one way only.
steve frank
