WTF!!!! Broken Valve Spring
Old Aug 21, 2002 | 06:42 PM
01SStud's Avatar
Default WTF!!!! Broken Valve Spring
Had the cam and valvetrain for a month and took it to Ed Wrights and everything was great. Went to the track and the car ran just fine there and back. ALthough when i was driving home from school today I heard a clicking noise coming from the motor. I have Comp 918's and titanium retainers, arnt they strong, i thought...and a 230/224 111 cam. WTF is the deal and why do you guys think it broke. BTW, I have only been spinning the cam up to 6400, so i know it hasnt been from spinning it to high, please help <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Chris <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Aug 21, 2002 | 06:52 PM
Frank's Avatar
Default Re: WTF!!!! Broken Valve Spring
Are you sure it's broken? A noisier valve train is expected from a cam/head swap.
I've never broken a spring (not yet) but I hear it's pretty obvious, the SES light is supposed to flash and the car runs real crappy.
Again, I've never broken a spring but have read quite a bit about it.
Frank
Old Aug 21, 2002 | 06:57 PM
DriveATransAm's Avatar
you would know if you broke a spring. maybe its just a loose rocker?
Old Aug 21, 2002 | 07:52 PM
Silver Slayer's Avatar
After my cam install, my valvetrain did not get really loud until about 2-3 weeks later. I pulled the valve covers three times checking for loose rockers, but never found any. I have now just learned to accept it. Hopefully it is the same in your case.
Good luck,
Kevin
Old Aug 21, 2002 | 08:03 PM
98TAauto's Avatar
if you have atap log for misfires... if one cyl has like 60-100+ then its probably a broken spring..
my car just seemed like it had a VERY BAD misfire when mine broke.. you could also have one cracked but possibly not be able to see it.
then again it could just be a loud valve train. But if your car feels like a slug check the springs ASAP!! see my broken 918 post below <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
comp wants me to send in my broken 918 so they can figure out why it broke. But a few 918's have been snapping
Old Aug 21, 2002 | 10:13 PM
01SStud's Avatar
THanks guys, but it is not a noisy valvetrain, it is a very very very loud knock,ticking noise, coming from the passenger side. My good friend who has a 11 flat T/A and is a mechanic said he is 99% sure it is a broken spring, he has broken two. Hopefully it is a loose rocker, but i doubt it.
Old Aug 21, 2002 | 10:18 PM
BIGBOS's Avatar
When I broke my 941 the SES light started flashing, and the car felt like a 4 cylinder.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ran like ****, would barely start, etc, loud "broken" sound coming from the valvecover
Old Aug 21, 2002 | 10:25 PM
Badazzvette's Avatar
I broke a dual Rev valve right after my head and cam install. With the dual spring, I drove it a few miles to get it home. She was misfiring and running like ****, SES light looked like a UFO and would barely idle. If you have a single spring setup, whatever you do, don't drive it. Get that valve cover off and check for a cracked or broken spring and replace it. Check the compression of that cylinder to make sure you didn't bend the valve.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 01SStud:
<strong>Had the cam and valvetrain for a month and took it to Ed Wrights and everything was great. Went to the track and the car ran just fine there and back. ALthough when i was driving home from school today I heard a clicking noise coming from the motor. I have Comp 918's and titanium retainers, arnt they strong, i thought...and a 230/224 111 cam. WTF is the deal and why do you guys think it broke. BTW, I have only been spinning the cam up to 6400, so i know it hasnt been from spinning it to high, please help <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Chris <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Aug 21, 2002 | 11:08 PM
StevieZ's Avatar
So pull the frickin valve cover and take a look! No sense in guessing when the answer is 10min. of work away.
Old Aug 22, 2002 | 03:55 AM
J'sRamAir's Avatar
What about a really bent rod(s)? Got hardened rods?
Old Aug 22, 2002 | 07:37 AM
98TAauto's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by StevieZ:
<strong>So pull the frickin valve cover and take a look! No sense in guessing when the answer is 10min. of work away.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">my thoughts exactly.. it doesnt take but 10 mins to pull the cover <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
