Oil cumsumption (leakdown-compression test)
For those that have not read my other post I have a 2000 SS with 15k miles on it that started using oil like crazy right after the Comp. cam was installed. It uses about 1 qt. every couple hundred miles unless I rag on it then a little more. It smokes bad at wide open throttle.
What I am wandering now is could it be the heads evan thought this is my second set. The first set was changed due to the smoking problem for a low mileage 2001 set. I am wandering if the cam is not right or something else besides the rings are bad.
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I installed a hotcam and have the exact same problems as you.... well i pulled the motor down last weekend, the rings are completely shot, no taper and the oil rings were pitifull, completely collapsed. I'm hoping that was the problem, the oil rings, the valve seals and guides are in great shape, no signs of bad valves or oil in the intake.... all that is left is rings, and after seeing how small the rings really are, i'm surprised more people don't have that problem.
I'll let you know in a about 2 weeks if that corrected my problems <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
FYI, i put the stock cam back in but did not help my condition any <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
