View Poll Results: yella terra or harland sharp
yella terra
96
51.89%
harland sharp
89
48.11%
Voters: 185. You may not vote on this poll
yella terra vs. harland sharp..
Old Mar 7, 2007 | 10:07 PM
ls2 bait's Avatar
damn harland made a serious run for the money shot here this past day. keep em coming.
Old Mar 8, 2007 | 04:34 PM
02 z/28's Avatar
harland
Old Mar 8, 2007 | 05:36 PM
BBADWS6's Avatar
HS on my car, and I love them. Car peaks at 6700 and I can rev it as high as I want with no valve float.
Old Mar 8, 2007 | 06:48 PM
JaSSon's Avatar
Ive been running the old YTs for 3yrs now with no issues.
Old Mar 8, 2007 | 07:30 PM
Gunnar@Patriot's Avatar
We sell ALOT of the Harland rockers. We have heard all good things from customers. On a personal note, I have owned several sets of their rockers and have always done well with them.
Old Mar 10, 2007 | 05:25 PM
ls2 bait's Avatar
so anyone know if they will work on the tfs heads or not? id have to assume they would beings they are still a roller tip.
Old Mar 10, 2007 | 09:14 PM
bfhawki's Avatar
I just installed the new Yella Terra's ultra-lights #6645 on my Vette this past week. My main reason was to try to get rid of some valve train noise and also make sure I don't get any needle bearings in the oil pan. These rockers are impressive to look at and very well designed. My car gets to 6500 rpm in a hurry with no valve float. I am using TSP Stage 2.5 5.3L heads that have the dual springs, 224/228 Comp Cam, .045 Cometic head gaskets, and 7.4 push rods. Valve train noise seems to be the same as before, maybe just a bit quieter, but not much.
Old Mar 23, 2007 | 12:18 AM
Rob's Avatar
Rob
Mine did get a lot quieter with the Yella Terra's. And no problems going past 6500 either. They must have added some HP as now the clutch slips on the dyno around 5600
Old Mar 24, 2007 | 05:34 PM
slowride's Avatar
Any of you guys that switched from stock to either these two rocker arms need to change push rod length?
Old Mar 25, 2007 | 12:45 AM
NemesisC5's Avatar
Originally Posted by Patrick G
Yella Terra has stepped it up a notch with their brand new Ultra Light shaft mounted rockers. Part number 6645. They are much lighter than the old Yella Terras. Most of the weight is centered around the trunion. The roller tip is super light. A few people on the board are running them. I should be running some before the end of the month!
Just had them installed at 21st CMC on my 99 Vette along with AFR 8019 springs. Added insurance for 6900rpm rev limit. 657rwhp/574rwtq
Old Mar 25, 2007 | 08:44 PM
DOHCsky's Avatar
what are the rpm range for the rockers? do either have an advantage over the other in this area?
Old Apr 2, 2007 | 11:10 PM
  #32
Cobra4B's Avatar
The Yella Terras are lighter now and don't have the upper RPM fall off that the HS and YT used to be associated with.
Old Apr 3, 2007 | 02:41 AM
  #33
Phantompooper's Avatar
I too had to grind both my stock LS1 heads and my replacement LS6 heads to get the Harland Sharp rockers to fit in there. So far, no problems, but my valvetrain sounds like a sewing machine.
Old Apr 3, 2007 | 05:09 AM
  #34
cowboysfan's Avatar
same question here.
Old Apr 3, 2007 | 08:04 AM
  #35
Smitty's '04 GTO's Avatar
Any of the Yella Terra owners have to grind the valve covers for clearance? I have a set going in this week on a heads/cam swap that is in progress. Just looking for what to expect the first time I fire it to break in the valvesprings...
Old Apr 3, 2007 | 09:46 AM
  #36
Rob's Avatar
Rob
Originally Posted by cowboysfan
same question here.
I used the same pushrods, so no change for me.
  #37
Rob's Avatar
Rob
Nope. Just bolt and go.
Old Apr 3, 2007 | 03:33 PM
  #38
exSSer's Avatar
That's what was I put on with my TF heads. No fitment problems, and they look like they're well made. And yes, roller tips.
Old Apr 3, 2007 | 09:29 PM
  #39
Dan_the_C5_Man's Avatar
YT's (anyone here old enough to remember Y&T?), and I sure hope they work because I've already ordered them.
Old Apr 4, 2007 | 01:44 PM
  #40
cowboysfan's Avatar
Yesterday & Today. "summertime girls" sorry lets not hijack here but, I have been reading alot of new thing about YT. I got them waiting for me at home. rwady to be installed when I get there.
