View Poll Results: yella terra or harland sharp
yella terra
96
51.89%
harland sharp
89
48.11%
Voters: 185. You may not vote on this poll
yella terra vs. harland sharp..
Old Sep 2, 2007 | 02:43 AM
  #81
jareed02's Avatar
ive heard bad things about the hs rockers breaking
Old Sep 2, 2007 | 08:10 AM
  #82
StevieZ's Avatar
I've had the YTs 1st design in for 25k miles (5 years) with no problems. I had to grind the 98 perimter bolt valve covers for them to work.
Old Sep 2, 2007 | 03:07 PM
  #83
Mike @ New Era's Avatar
The new lightweight design fits the 98 model with perimeter bolt valve covers without any modifications , I have installed them on a 98 vette and 98 trans am and no modifications were needed , just bolt right in .
Mike
Old Sep 15, 2007 | 07:03 PM
  #84
cpd004's Avatar
The price difference now is bigger.
Old Sep 16, 2007 | 11:20 PM
  #85
Rowin Gearz's Avatar
I don't have any experience with the harland sharp rockers, but I do have YT's in both of my cars. I have not had any issues from either of mine. They are noisey but they seem to do a great job.
Old Sep 17, 2007 | 08:41 AM
  #86
cpd004's Avatar
http://www.mphparts.com/mm5/merchant..._Code=FBLS1VLV
Seems to be cheapest.
Old Sep 17, 2007 | 08:54 AM
  #87
nesikachad's Avatar
Solve all your problems.
Cost a few bucks more, but it's a track proven design from a company that sets the standard.
JESEL Valvetrain Innovation.
Old Sep 17, 2007 | 05:35 PM
  #88
cpd004's Avatar
Double the price is hardly a few bucks. I agree that they are the best though. Probably not many on here with them to comment though.
Old Sep 17, 2007 | 10:47 PM
  #89
curtbriggs's Avatar
Default Yella Terra Install
I just finished installing the Yella Terra #6645 on my 1999 C5 a few hours ago. AFR 205 heads, stock head gaskets, heads cut 0.028”, 7.400” push rods, Comp 224* 0.580” cam, stock lifters, PRC Ti retainers and double springs.
Purchased from New Era, $415. There are several grades of rockers from Yella Terra, the “Easy fit” direct replacement for original rockers and the Platinum/Platinum Plus. Their web site give some details. www.yellaterra.com.au
I had to chuck all the rocker bolts into my lath to remove a few thousands from the bolt shank to make the bolts fit into the rocker shaft holes. I tried taping a few in, some bolt shanks were so tight that I couldn’t tap them in with a machinist brass hammer. The few that would tap in were so tight that I couldn’t feel the threads engage in the AFR heads and they started to cross thread. If you don’t have a lath, chuck the bolts heads in an electric drill and run a file over the shank while they’re spinning. The rocker shafts are hardened, I couldn’t de-burr the holes with a scraper or a rat-tail file. The holes could have been finished with a smoother surface. The rest of the rockers are beautifully machined and all the tolerances that I could check with a dial caliper were spot on from set to set.
I had to use the supplied 0.048” shims to get a ½ turn pre load. My 1999 rocker bolts are 20 tpi or 125m thread. 20 tpi equals 0.050” travel for one turn of the bolt. They must be an oddball metric size, they were larger than 8m125 and smaller than 9m125.
I couldn’t find a midget to hold the push rods to tell me when they stopped spinning. I could only get one index finger on one hand and maybe the little finger on the other hand on a push rod. The push rods lie to you, they feel like they’re turning and they aren’t as I marked them with a drop of white paint, I could not get an accurate zero setting using this procedure. Maybe this is why some have a problem with their installation.
What I did and I thought it worked great was put a cylinder at TDC and tight down on the rocker bolt with a 0.013” feeler gage until you couldn’t move the feeler gage and back off the rocker bolt until the feeler gage just moved. I used a 0.013” feeler gage because this is ¼ turn with the 20 tpi rocker bolt. (Well, close enough!) I removed the feeler gage and went ¼ turn in for zero preload on the lifter. If you can push down on the push rod with your thumb, the lifter has collapsed, in this case just watch the rocker when you pull the feeler gage out, if the push rod end of the rocker moved up, you were compressing the lifter internal spring so do it over again until it doesn’t move. I did this on both banks incase there was a tolerance stack, both banks came out the same. I got an acceptable wipe pattern on the valve stem. Yella Terra instructions call for ½ to ¾ turn past zero preload.
With my head, gasket, cam and push rod length, I had to use one 0.048” shim under each stand. This gave me a 0.023” pre load when torqued down to 22 foot lbs. About ½ a turn, the instructions call for ½ to ¾ turn past zero pre load. I didn’t follow the shop manual procedure for installing each rocker because with the Yella Terra common shaft for both intake and exhaust rockers you will put the shaft in a bind and could maybe bend a bolt. Just turn both bolts down evenly so as to not bind the bolts in the shaft bolthole. The rockers didn’t hit the valve covers and they had good clearance on my double springs.
The motor is as quiet as before and I had a stock rocker puke it’s needle bearings on one side. The bad stock rocker didn’t make any valve train noise that I could hear. The bad rocker had a noticeable valve stem off center wear pattern. I did a DE at VIR and from the wear mark, it might have happened just before or at the beginning of the DE, I had trailered the car and hadn’t driven it since. I found two needles in two cylinder stud holes and a bearing cage with one of them. I’ll look for the rest when I change the oil.
I went into detail on this to help those who have never had to deal with a system that has to seat on the head and also have the correct lifter preload set. Not like adjusting the hydraulic lifters on an old small block, with a friction lock nut. I read all the threads and David Vizard’s valve train book (doesn’t cover the LSx) and I can see why there is so much confusion. Anyone who can add to this or catches a mistake, please jump in.
Cheers, Curt
Old Sep 17, 2007 | 10:58 PM
  #90
Dan_the_C5_Man's Avatar
"I had to chuck all the rocker bolts into my lath to remove a few thousands from the bolt shank to make the bolts fit into the rocker shaft holes."
Interesting; I did not experience this, and I can't remember reading about anyone else having this issue either.
Old Sep 18, 2007 | 05:49 AM
  #91
nesikachad's Avatar
I have a set ready to go on as soon as the heads show up.
We'll see!
Old Sep 23, 2007 | 12:22 PM
  #92
Jeff@TotalPerformanceEng's Avatar
I agree.. I never had any of these issues either. Hell, I didnt even have to use the shims..
Old Sep 23, 2007 | 12:58 PM
  #93
Viper's Avatar
I thought shims were for valve swipe not preload....
Old Sep 23, 2007 | 02:08 PM
  #94
vettenuts's Avatar
Correct. However, if you can stay with a good swipe and have sensitive preload rockers (my Morel's have a pretty tight tolerance on preload) then you can use the shims to alter the preload to some degree. However, they should be used first to establish a proper wipe pattern. I found the Yella Terra instructions to be very confusing as they cover several different installations. Also, LS1HowTo has this information incorrect as well and is misleading a lot of people.
Old Sep 23, 2007 | 03:28 PM
  #95
Viper's Avatar
How would you change the wording on that write up to be? I've got the Morels as well. Stock rockers for now modified by Harland.
Old Sep 23, 2007 | 11:00 PM
  #96
studderin's Avatar
I've installed several sets of the YT right off the shelf, we stock for $389. And never had any rocker bolt, or any clearance issues?
Old Sep 24, 2007 | 05:49 AM
  #97
vettenuts's Avatar
I would use checking springs and first check the wipe pattern. Once that is set I would measure for preload. The Morels like 0.030" - 0.050" preload based on my discussions with Rick Morel. Since most pushrods come in 0.050" increments, then you run the risk of falling outside that range. Choice is either custom pushrods or slightly altering the shim. For example, if you find you need a 7.465 pushrod to get you into the range, then shaving 0.010 from the shim will put you into the range but you must re-check the wipe. Each 0.010" of shim equal 0.016" of preload change due to the rocker ratio (2.7/1.7 X 0.010" = 0.016"). So you can play both sides (shim and preload) but you have keep checking both. I also plan to go with the 0.116" wall Smith Brothers pushrods since the reported pushrod flex on the LSx engines from Spintron testing is pretty severe, which is one of the reasons Crane just introduced 3/8 pushrods and guide plates for their rockers. I also think 3/8" pushrods are a must for TFS or ETP heads due to the much longer lengths.
Old Sep 24, 2007 | 10:17 AM
  #98
Cobra4B's Avatar
To me the ls1howto directions mirrored the YT directions I got. I installed them w/o shims.
I put the first cylinder at TDC so both valves were closed. I then installed the rocker arms and tightened the bolts using my fingers on the socket and got them hand tight per the instructions. I then turned each bolt in 1/4 turn increments until they checked up and were wrench tight. The instructions called for up to 1 full turn (or was it 1.5) before the shims were needed. It spoke of checking wipe pattern, but specifically stated the use of the shims was to reduce pre-load, but it makes sense that wipe pattern would be adjusted. Mine took just under 1 full turn to check up (almost 4 1/4 turns). So... per instructions I did not have to use the shims.
I've got 8000 miles on them w/o issue and 2 HPDE runs. No odd noises... just normal valvetrain noise post-cam. I'm using the LGM supplied 7.4 pushrods.
Old Sep 27, 2007 | 04:22 PM
  #99
vettenuts's Avatar
I personally think the YT instructions are very misleading and should be written specifically for the application.
Old Sep 27, 2007 | 09:46 PM
  #100
Cobra4B's Avatar
Well I've got almost 8k on them and my car just made 436/397 w/ a proper tune... no odd noises... have run 2 HPDEs. I figue I'd have broken it by now if anything was wrong.
Oh... and my numbers are w/ stock heads, an X2 cam, cats, stock water pump, stock TB, stock manifold.
I think the numbers are a bit higher than other X2 (and even X3) cars because of the rockers and my aluminum flywheel.
