Dynoed the "aggressive" H/C setup
For those interested...here are the specs:
Budget freshening of the bottom end:
Total Seal rings, stock pistons, stock rods, stock crank, Clevite 77 rod bearings, Federal Mogul Main bearings, ARP Pro2000 rod bolts, Katech oil pump
Top end:
GTP S2 Heads (5.3L milled .040) ~11.8:1 compression, MTI T2 camshaft (232/232 .574/.574 112) Crane OEM lifters, etc
Remember these are "low" numbers due to the severely parasitic driveline (9" Ford, 35 spline axles 4.71 gears and 3.5" custom STEEL driveshaft)
I also included my best dyno with the old B1 cam I ran so well with <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://www.wam.umd.edu/~krzew/newdyno.jpg" alt=" - " />
That looks like some spunk stains on the dyno sheet. I would be excited too but come on. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Justin
<small>[ August 24, 2002, 06:24 PM: Message edited by: Jsears8 ]</small>
<strong>What made you go with the ford niner, instead of a Moser 9" or a 12 bolt?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">it is a Moser 9" But I just said Ford to be generic. went 9" due so I could get a locker....I'd just break posis and don't really want a spool <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
What I find funny is that I did everything wrong <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Too big of a cam, too big of a header for a 346 (Dynatech Stepped headers), etc...
<small>[ August 24, 2002, 07:11 PM: Message edited by: Fireball ]</small>
I told you it was going to peak between 6400-6500. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> lol
I think I'm gonna try sticking in my "smaller" MMS 229 cam I have and try again to see what effect that may have. I have a feeling overall power may stay unchanged but may get a boost in torque <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Guess I need to try it and see <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
If it loses area under the curve...then I'll put the bigboy back in <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
