MS4 110 Lsa First start up
http://www.youtube.com/watch?v=aEe1PBAcgzI
Got a little giddy and wanted to get out of the car to check valvetrain noise..
oil psi went to 40 right away.
This is on the stock tune... idle is around 1700, had to disconnect the pcv to get a decent idle.
Ill post the raw sound from the rear some time this week after a small tune.
car will not be 100% tuned untill after a 98 - 02 pcm change over.
I'm installing mine this weekend on a 11lsa. I hope to hell it sounds like that!
Prc spring package =]
This morning I paid to have the car washed (had to be at work) and it was soo funny to watch the 18 year old kids try and pull my car forward!
Best advice I can offer!
1.Take your time
2.Do everything right
3.5/16 wooden dowel rods
4.Magnetic pen to pick the locks up from the valvestem
5.loc tite or grease to stick the locks on the valve stem
6.Fishing line on the 10mm oil pickup tube bolt.
7.Moore VS compressor all the way!!
8.Take the oil pump apart to put it back on
9.New timing chain
10. Extra pair of undies! (for startup)
I used a regular plastic straw to find top dead center
It's got longtubes 3" Xpipe and couple small spinetech mufflers.... but I may just run LT's/bullets and dumps.
1.Take your time *will do
2.Do everything right *will try my best
3.5/16 wooden dowel rods *Check
4.Magnetic pen to pick the locks up from the valvestem *Check
5.loc tite or grease to stick the locks on the valve stem *Check
6.Fishing line on the 10mm oil pickup tube bolt. * Sure I can find some laying around. Meaning B4 its all the way out and drops in the pan?
7.Moore VS compressor all the way!! *Barrowing buddys tool
8.Take the oil pump apart to put it back on *New blueprinted TSP pump(tak eapart?)
9.New timing chain *probably not this time.
Can you get a pic of it? The seats are a really snug fit once you drop them in.
You are talking about the Dark colored seats, right? not the titanium Retainers?
Go to the dealership and ask for a LS2 chain.. if your going to pull the pump you might as well do a chain. The Ls1 chain is no nearly as beefy as the ls2.
There are like 4-8 10mm bolts on the front of the oil pump. (forget how many)
the inside of the pump is just 2 gear looking peices. Put the big gear peice on first and the fit the smaller one in.
Fishing line you use when putting the new bolt in.
That should sound sick! My grind card was nothing but 0's....
Ill have them re send mine out..
Tci 3000... Wayyy to small...
Needs a 4k 0r a 4.2k
Hey you used to be with FTV6 right?
Post up some vids out of the garage and some road time. Would love to see and hear it.
-J
-J
