MS4 110 Lsa First start up
Old 03-06-2007, 07:33 AM
jub jub's Avatar
That cam sounds crazy wicked. I like it!
Old 03-06-2007, 07:49 AM
PREDATOR-Z's Avatar
Originally Posted by KrisXpc
http://www.youtube.com/watch?v=Kl0iLy2j7n0
Got a little giddy and wanted to get out of the car to check valvetrain noise..
oil psi went to 40 right away.
This is on the stock tune... idle is around 1700, had to disconnect the pcv to get a decent idle.
Ill post the raw sound from the rear some time this week after a small tune.
car will not be 100% tuned untill after a 98 - 02 pcm change over.
Congrats,
By disconnecting the PCV you had a lot of unmetered air and that is not a wise thing to do. Be careful in you anticipation to drive that thing, get it tuned asap.
Old 03-06-2007, 08:42 AM
Specialized's Avatar
Congrats, By disconnecting the PCV you had a lot of unmetered air and that is not a wise thing to do. Be careful in you anticipation to drive that thing, get it tuned asap.
Was just gonna say that.
I think (no offense) that it sounds like *** idling that high. Get the idle down, I want to hear the chop. Otherwise, congratulations
Old 03-06-2007, 11:21 AM
KrisXpc's Avatar
I agree, this thing is going to mad chop. The Base tune goes in thurs. Sat we start the pcm swap.
Old 03-06-2007, 11:43 AM
jub jub's Avatar
That thing has a little over 18 degrees of overlap so a low RPM idle will be out of the question. Even idling at 1700 rpm it was loping pretty bad.
Old 03-06-2007, 11:57 AM
KrisXpc's Avatar
You underestimate my tuner =P
Idle will be set to around 950... I hope
The biggest thing is 98's are a nightmare to tune. Thats why I'm stressing getting this 02 pcm done.
Old 03-06-2007, 12:11 PM
Trunion King
bene's Avatar
Tci 3000... Wayyy to small...
Needs a 4k 0r a 4.2k
Hey you used to be with FTV6 right?
Yep. Enjoying the LS1 powa like you now.
Old 03-06-2007, 12:45 PM
4U2BNVS's Avatar
I hope to have mine started this week I have the same cam MS4 on a 110 LSA wasn't sure if it would clear also have PRC stage 1 heads and longtubes with an x-pipe and bullets dumped at the rear I can't wait.
Old 03-06-2007, 12:55 PM
tuffass's Avatar
Thats really odd... All of my seats felt perfectly smooth.
Can you get a pic of it? The seats are a really snug fit once you drop them in.
You are talking about the Dark colored seats, right? not the titanium Retainers?
Yes, it's wierd. It looks like these two were pressed because the bottom is curved up into the lip. Like a washer was pressed onto a pole making a seat out of it. I called TSP and they want me to send them a pic but I have to wait until I get home oobviously before I can do that.
I also noticed that some have an angled lip and some it's exactly square or even. Strange that I got 3 diff seats with the kit.
Old 03-06-2007, 12:59 PM
tuffass's Avatar
Originally Posted by dadem0n
Everything Ive read says MS4 fits fine with stock heads
Exactly what I've heard. Everything that I've heard with people running into issues are with ported or milled heads.
Old 03-06-2007, 02:26 PM
transamfreak01's Avatar
from what i have read, flycutting is not required unless on a 110lsa but anything higher does not need it. jus what i read
Old 03-06-2007, 02:27 PM
  #32
KrisXpc's Avatar
Not on stock heads..
Old 03-06-2007, 02:36 PM
  #33
RocketCutlass's Avatar
whats the advantages of a 110lsa? i dont really know what the hp difference would be between the 110 111 112... just wondering?
Old 03-06-2007, 03:00 PM
  #34
CASHss99's Avatar
congrats i put the g5x3 in getting it tuned the 19th.. i drive mine around the only time it has a hard time stayin alive in start up every morning.. how bout you?
Old 03-06-2007, 03:32 PM
  #35
KrisXpc's Avatar
Here ya go guys. By popular demand! http://www.youtube.com/watch?v=aEe1PBAcgzI
Old 03-06-2007, 03:35 PM
  #36
pdd
pdd's Avatar
nice
Old 03-06-2007, 03:57 PM
  #37
CASHss99's Avatar
very nice so the only way you stay idle is taking off pcv?
Old 03-06-2007, 04:07 PM
  #38
99zman's Avatar
that sounds wicked......
Old 03-06-2007, 07:23 PM
  #39
KrisXpc's Avatar
To be 100% honest, the pcv was shot.. so I yanked it all off to put some new tubing on...
It might run with it on.. but i doubt it..
Old 03-06-2007, 11:07 PM
  #40
PREDATOR-Z's Avatar
I think you have serious misconceptions about working on your motor. Don't take this the wrong way but you are doing what is not supposed to be done.
MS4 110 will have unsafe PTV clearance and you'll kiss your pistons. Just because a cam allows the motor to turn over, doesn't mean it clears.
Be prepared to get some valve work done and possibly a new motor.
You have been warned
Quick Reply: MS4 110 Lsa First start up
