LS6 PCV qustion?
Old Aug 27, 2002 | 04:19 PM
badls1's Avatar
Default LS6 PCV qustion?
When upgrading to the LS6 PCV system do you have to plug the valve cover out lets? Cause I bought the LS6 valley cover with the tube. It looks that you connect the valley cover right into the manifold. Would someone please tell me how this setup works.
Thanks in advance, Harry.
Old Aug 27, 2002 | 04:30 PM
XtraCajunSS's Avatar
Default Re: LS6 PCV qustion?
Yes, in order for a PCV system to funtion properly, it must be a sealed system. Since you will be pulling crankcase vapors from the center valley, you will need to plug the outlets on the valvecovers and route the line straight to the throttle body with the PCV valve inline...
Shane
Old Aug 29, 2002 | 09:07 PM
Go Texas Tech's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by badls1:
<strong>When upgrading to the LS6 PCV system do you have to plug the valve cover out lets? Cause I bought the LS6 valley cover with the tube. It looks that you connect the valley cover right into the manifold. Would someone please tell me how this setup works.
Thanks in advance, Harry.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">https://ls1tech.com/ubb/ultimatebb.p...=000075#000009
Cut and paste the url into a new window to see the pictures.
<small>[ August 29, 2002, 09:15 PM: Message edited by: Teddy98Z28M6 ]</small>
