vortec heads for ls1?
Old Aug 28, 2002 | 07:18 PM
wicked-98's Avatar
Default vortec heads for ls1?
Does anyone know the part # for the vortec heads that bolt on to the ls1 block.I seen the article on gm high tech performance some guy had them ported and bolted on with a cam and is making 420+hp to the wheels <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
<small>[ August 28, 2002, 07:19 PM: Message edited by: wicked-98 ]</small>
Old Aug 29, 2002 | 06:54 AM
Camaroholic's Avatar
Default Re: vortec heads for ls1?
Seeing how GM likes to call every freaking V8 truck engine a "Vortec" engine, it's probably "just" a set of 5.3L LS1 heads. Yes, you cut 'em with new valves, port 'em, and they'll do 415-430 RWHP. But it's not as simple as an average Joe getting a Standard Abrasives kit and doing the porting. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
My guess is that someone like Craig at GTP was involved somewhere. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Andrew
Old Aug 29, 2002 | 07:00 AM
RyanJ's Avatar
SSU Moderator
was it a sunset orange car? i bet it was the AMS car. the porting was done in house at AMS, not at GTP.
Old Aug 31, 2002 | 03:47 PM
wicked-98's Avatar
Yeah it was the ams trans am.Could you port our stock heads like that too and make the same power
<small>[ August 31, 2002, 03:58 PM: Message edited by: wicked-98 ]</small>
Old Aug 31, 2002 | 04:02 PM
Jason99T/A's Avatar
I can shift faster than you.
Yes, you'd just have to mill them more to raise the compression the same amount.
Old Aug 31, 2002 | 08:02 PM
menikmati's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Camaroholic:
<strong>Seeing how GM likes to call every freaking V8 truck engine a "Vortec" engine, it's probably "just" a set of 5.3L LS1 heads. Yes, you cut 'em with new valves, port 'em, and they'll do 415-430 RWHP. But it's not as simple as an average Joe getting a Standard Abrasives kit and doing the porting. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Andrew</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">they were the 4.8L heads
Old Aug 31, 2002 | 11:45 PM
wicked-98's Avatar
Then I'll probobly buy the lr4 heads instead and then get them ported <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 1, 2002 | 12:11 AM
CashDudeHomie's Avatar
The 4.8 and 5.3 heads are the same thing. Even the 5.3 heads have "4.8" cast onto them.
Old Sep 1, 2002 | 10:10 AM
LS1derfull's Avatar
The name Vortech has been used so much by GM because they havebeen gradually introducing heads with port designs that emphasize swirl function into cylinder. At first the attempt was crude on Gen 1 motors but then progressed into LT1 design and Gen 1 truck heads, then finally the great LS1 compromise of great flow and phenominal port swirl for excellent combustion and atomization. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
