A little P to V clearence question.....
Old Aug 28, 2002 | 08:30 PM
02 Silver Z's Avatar
Default A little P to V clearence question.....
I`m eyeballin` a set of 5.3 heads I can get a good deal on. They are not milled and have stock size valves and I would be using stock, or, at least stock thickness head gaskets and a reverse split 227/224 .569/563 cam. Can I use stock length push rods and still have enough piston to valve clearence? Assuming I did, would I be ok if I installed larger than stock valves? Please excuse my ignorance, but this will be my first time rippin` into the all powerful LS1 and I am not well schooled on my clearences yet. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Aug 29, 2002 | 01:21 AM
AlonzoVersion 1.0's Avatar
Default Re: A little P to V clearence question.....
You will be fine.You can go as big as 2.02 and 1.57 on the intake/exhaust without new seats.You have a lot of play sense the heads arent milled.
Old Aug 29, 2002 | 03:05 PM
Thanks for the reply Alonzo. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
