about to do a cam swap have a question
Old Mar 6, 2007 | 03:58 PM
PewterSSLS1's Avatar
Default about to do a cam swap have a question
i'm about to start my cam swap tommrow i'm going with the torquer v2 cam, 232/234 595/598 112, and i have patriot performance stage 2 heads 64cc not milled at all on, think i will run into ptv problems or should i be alright
Old Mar 6, 2007 | 04:52 PM
SSwt00SS's Avatar
i believe you will be fine. i called Gunnar last week in regards to installing a Torquer v2 in my car that has the Stage II Ls6 heads w/59cc chambers and he said it would not require flycutting, although he recommended a clay test to be done. Call Patriot and double check with them first.
btw, how do you like the 90/90 combo? i'm looking into going w/that when i put the cam in...
