Changing rod bolts with engine in the car
LS1derfull, you cant just check the torque readings on the stock bolts as they are torque to yield.
How in the hell do you go back and diagnose a rod bolt was the culprit of a bottom end failure when everything turns to mush?
Is it worth the risk of changing the bolts without disassembling, sizing and re-balancing? The sales staff at Katech will say, 'Go for it!', but what to machine shop people think? Both sides are probably biased.
Maybe someone could ask an independent tuner or two about changing just the bolts without disassembling, resizing, etc.
So maybe they are just bolt-ins?
Make sure to use the supplied lube from ARP. Instructions say to torque to 45 ft lbs. Loosen bolt then torque to 45 ft lbs. Loosen again and torque to 45 ft lbs.
After I torque all this way I went over them to double check the torque. They were all perfect.
Unless you are making some crazy horsepower, I would recommend that you stay with the GM Bolts. Normally if a GM rod bolt breaks it is becuase something else broke first and placed an extreme amount of pressure on the bolt.
Then I put a transmission jack under the left front bottom arm and removed the bolt and steering rack arm connection. Then I unbolted the shocks at the bottom and lowered the transmission jack. Then did the same to the right one. At this point the crossmember was disconnected from the wheels.
I then removed the two steering rack bolts and the four bolts holding the ABS controller to the crossmember and the power steering cooler.
I then unclamped all the hard lines and the harness that runs along the front crossmember.
Then I removed the four bolts holding the crossmember up with the transmission jack under it and slowly lowered it and got it out of the way.
For the most part the oil pan mounting bolts were easy to get to except for one on the passenger sid in the middle. It was a bear because it was between two aluminum strengthening bars and was up behind the headers and right above the sump horn. I was able to get it with the a ratchet wrench kind of wedged in there and got one click at a time. It took about 30 minutes to get out but I kept at it and it finally came out. Putting it back was just as bad.
Once I removed all the bolts (and had the oil drained and filter removed previously) The pan came right down. The gasket was ruined when I removed it. It broke in several places and remnants were caked to the block an pan and had to be removed with a plastic scraper.
The windage tray and pickup tube came next. I removed the pickup tube first which meant I had to remove the two bolts from the oil pump. Make sure you also have a new oil pump O-ring. Then the windage tray can be removed.
Once the tray is out of the way you can get to the bolts. The rods are right there. I got a 24mm socket and put it on my long ratchet handle and rotated the motor slowly with that to get to each rod.
I used the ARP pros. I put some moly lube that came with them on the bolt threads and a little under the cap. I remove one stock bolt at a time and replaced it with one ARP bolt at a time and torqued them to 40lb/ft 3 times with the 3rd time the clamp as per the instructions. I checked my rod side play with a feeler and it didn't change and I was able to get a thin .002 plastic-gauge in btween the rod and bearing and it didn't change with the ARP's installed. I know that isn't the best way to check them and is not accurate but it showed me the caps didn't go out of round enough to change the bearing clearance, at least where I was able to measure with the guage.
After they were all in, I went over the whole bunch again to make sure they were all at the correct torque.
I then replaced the windage tray and pickup tube.
Then I cleaned and prepped the pan mating surface and the block mating surface. This was harder that you might think because doing it from the bottom I had to put the RTV bead in the corners after I dried it off and also the whole mating surface, as GM specs the gasket to be mounted dry. Once we had the rtv inplace on the block and the gasket placed on the pan, a friend and me got the pan up and put bolts into the corners finger tight. Then we got the rest in finger tight and kept checking the pan alignment. Once all the bolts were in we tightened them to spec in 2 passes on alternating sides.
Then we put back the crossmember, etc. I have a bunch of pics if you would like I can send them to you. It might help you visualize what you will need to do.
One thing I noticed was the ARP Pro's were longer than the stockers so the torque load is spread out over a longer distance. They were also slightly heavier but that hasn't been an issue for me. No vibrations, etc.
I have just finished putting about 400miles on them and have nailed it few times and all seems weel so far.
How many times did you/should you TQ, Loosen and Re-TQ to properly stretch the rod bolts during install?
BTW, I have about 450 miles on them now and have been woking the motor more and more. I took it to the rev limiter yesterday and all had been well. This week we are doing AFR 205's, cam, and LS6 PCV conversion. If all goes well, dyno next weekend and I'll post the results.
