Will the Bottom End crap on me?
Old Mar 7, 2007 | 06:11 PM
BlackHoleSunSS's Avatar
Default Will the Bottom End crap on me?
Well, I am doing LS6 intake/ported heads, TREx, LT's, LS7 lifters, LS2 timing chain, hardened 7.400 pushrods, PRC dual spring kit and an LS6 oil pump. Doing ARP head bolts as well.
I am wondering if the stock bottom end will crap on me when I get a tune and rev this engine with this new setup? I hear things about the con-rod bolts and am curious. I just have bolt-ons as of now with 113k miles on the clock, M6.
Thanks!
Old Mar 7, 2007 | 07:05 PM
Jbmoney21's Avatar
You will be fine. But i would put some ARP rod bolts in it just to be on the safe side
Old Mar 7, 2007 | 07:19 PM
john563's Avatar
Sorry to hijack,but it might pertain to your question.Does anyone know what a shop may charge to swap out rod bolts? How long would it take(labor hours)?
Old Mar 7, 2007 | 07:30 PM
02Z06MATT's Avatar
Personally IMO if I were you I would look into building a shortblock b\c that is a lot of miles. I have a 02 Z06 w\ 8000 miles on it, I sprayed it w\ a 100 shot wet, stretched a rod bolt and cracked the #7 piston in half. Most guys know it as the dreaded #7 piston try search and you will find the thread about this. Anyway good luck man I hope she holds up.
Old Mar 7, 2007 | 07:34 PM
00BlueTA's Avatar
I think if you stay na you will be okay, I wouldnt spray on a motor with that many miles on it But on the other hand, if you brake the bottom end you can get a forged one, and then bring on the N2O.
Old Mar 7, 2007 | 07:57 PM
Z28_DAD's Avatar
i know the oil pan gasket pays 4ish hours. i did it on my car under warranty and got paid for all of it instead of my 30% commission
Old Mar 7, 2007 | 07:59 PM
john563's Avatar
so basically 4-5 hours labor
Old Mar 7, 2007 | 08:01 PM
Z28_DAD's Avatar
yea, in that area. where do you live?
Old Mar 7, 2007 | 08:25 PM
john563's Avatar
Dayton OH
