Help with 5.3L heads quick!!
Old Sep 4, 2002 | 01:33 PM
VTtransam's Avatar
Default Help with 5.3L heads quick!!
Ok, i'm about to buy a set of 5.3L heads and have the ported and polished this winter. Should i use caution in using these heads for a stage 1 head/cam setup like the one in the latest issure of gm high tech? Any problems with these heads?? Will i need to have any machine work done to them asside from the normal port/polish job?? Any advice with these heads would be very helpfull. thanks in advance!!!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Sep 4, 2002 | 02:24 PM
XtraCajunSS's Avatar
Default Re: Help with 5.3L heads quick!!
I would get them done with larger valves. 2.02"/1.57" on a stock bore engine...
Shane
Old Sep 4, 2002 | 02:43 PM
Nasty N8's Avatar
Just larger valves.
Nate
