Roller tip rocker arms
Old Mar 8, 2007 | 10:54 AM
brad8266's Avatar
Default Roller tip rocker arms
Has anyone here used them before on an LS1? I havent heard of anyone using them, just wondering whos done it. I am thinking of buying a set to see if they help anything.
Old Mar 8, 2007 | 03:50 PM
david vericker's Avatar
You can't be serious!
Old Mar 8, 2007 | 05:56 PM
mr2guru's Avatar
Old Mar 8, 2007 | 05:57 PM
98RedZone's Avatar
A higher ratio should give some small gains. Just the roller tip with a 1.7 ratio probably nothing.
Old Mar 8, 2007 | 06:07 PM
LS1MCSS's Avatar
Check his post count.
Old Mar 8, 2007 | 06:09 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Nobody has ever done this...you'd be the first. Do it and post up the results!
Old Mar 8, 2007 | 06:10 PM
Ryan02SS's Avatar
I've been running YT 1.7's since 2003. I installed heads at the same time so no power gains could be noticed from just the rockers. When checking clearances etc, I noticed they provided a better sweep pattern over the valve tip than the stock rockers. I also noticed a quieter smoother valvetrain than before.
Old Mar 8, 2007 | 08:48 PM
brad8266's Avatar
You guys are some serious ********. Where the **** in my post did I say anything about power? Some of you need to learn to ******* read. I asked a simple question and I was expecting a simple response, not a bunch of BS and useless smartass comments.
All I wanted to know is if anyone used them and how did they like them. No ******* **** there isnt going to be any real power gains, I knew that already.
I cant wait till one of you ****** ask a question that i find stupid, ill be sure to go out of my way to make you feel like an idiot..
Old Mar 8, 2007 | 08:50 PM
brad8266's Avatar
Ok, Mr. Stockvette.
Old Mar 8, 2007 | 09:10 PM
Killer_Bluebird's Avatar
Yes and I do.
Old Mar 8, 2007 | 10:10 PM
MeentSS02's Avatar
It isn't that I was being a smartass...well, yeah, I was. But seriously...there have been a lot of threads about this lately, and if you would have just taken the time to do a search, you would have found plenty of results and opinions. You really just need to stop being lazy and do some footwork yourself instead of posting up a new thread about a topic that has been beaten to death countless times...
Old Mar 9, 2007 | 12:57 AM
JRracing's Avatar
Brad, don't let them blow you some **** because you asked a dumb question.
You just tell them to
My take on the RR's is that they are more stable and efficient. Less friction on the valve stems. I have a set of comp pro mags 1.75 I used on my last set up. They are up for sell if you are interested.
I plan on buying some 1.7's soon. But the stockers are going to have to do for now.
Old Mar 9, 2007 | 02:42 AM
PREDATOR-Z's Avatar
IMO, there are only 3 kinds of aftermarket worth the effort. Out of which only 1 has good power gain.
Comp Magnum 1.75
Jessel (my favorite)
and
Crane 1.72 variable lift.
YT, Harland, PP etc... are junk (like problematic). (not the new lightweight YTs but I do not have enough data on them yet)
This is IMO
Old Mar 9, 2007 | 02:57 AM
AmericanMuscle313's Avatar
Are there any adjustables that are worth the money?
Old Mar 9, 2007 | 05:27 AM
vettenuts's Avatar
I can only relay my experience. I spent last winter setting up my Dart heads on the workbench. I had checking springs installed and first tried the stock rockers. I found the wipe pattern was wide and in some cases off to the side of the valve stem (you can see this by looking at the rocker tip as well). I also tried shimming them and while I could move the patttern around on the valve stem, it wasn't acceptable in my opinion and I was worried about valve train stability at higher RPM.
I then set up the Crane roller rockers. Due to their adjustability, I obtained a much narrower and centered wipe pattern on the valve stem. So in my opinion, they are worth the effort to setup and install.
Old Mar 9, 2007 | 06:38 AM
brad8266's Avatar
I really wasnt referring to you. I didnt search because I am on here all day at work anyway and i see most of the threads that come through and I have not seen to my recollection a thread about roller tip rockers anytime recently.
Old Mar 9, 2007 | 06:39 AM
brad8266's Avatar
Yeah, I am not looking for power gains out of these anyway, I would buy them as more of a stability mod.
Old Mar 9, 2007 | 06:40 AM
brad8266's Avatar
This is the type of thing I was looking for, thanks man.
