Oil pressure Guage
<small>[ September 05, 2002, 01:35 PM: Message edited by: NataSS Inc ]</small>
There a plate right above the oil filter that unbolts. This is where the C5's get their oil temp from. You'll have to drill & tap the part on the F-body but it's no big deal. If you have stock cats, you'll have to remove the driver's side one to get at it. I tapped it with 1/8-27 NPT threads. The sending unit will interfere with the stock cat so I had to cobble together some fittings to move it about 3-4" forward. Used teflon tape on everything and I have zero leaks.
Run the signal and ground wires through the firewall using the supplied grommet. I ran the 12v wire to the instr. panel power fuse and the light to the IP dimmer fuse. Grounded the light to a metal brace under the steering column.
Good luck!
Here's his website: LS1 Monte Carlo SS conversion
He describes installing the sending unit in the August section.
