Minimum Piston to Valve Clearance
Old Mar 9, 2007 | 04:45 AM
Gregory's Avatar
Default Minimum Piston to Valve Clearance
What is the minimum piston to valve clearance a person can safely run?
I understand .100” is safe, but maybe some have gotten by with .075”.
This is important for me as I look for a camshaft to fit the L92 heads.
My Scoggin-Dickey built 402 has -14cc Mahle pistons and I am thinking of either of the two Comp Cams camshafts:
1.) XE-R 236/248 .602"/.615" 115+0
OR
2.) Grind: 3732R-3737R-HR114 .612/.616 lift, 244/248 duration, and 114 LSA
The head gasket is a Cometic that is .045 thick when compressed.
Thanks
Old Mar 9, 2007 | 06:23 AM
speedracer5532's Avatar
.100 Exhaust and .080 Intake.
Old Mar 9, 2007 | 06:44 AM
brad8266's Avatar
.100 exhaust/.080 intake You can get by with less, but you will be taking a risk, especially on a street car and if the block is not built to tight tolerances you run even more of a risk.
Either of those 2 cams should be fine since you have -14cc's in the pistons.
Old Mar 11, 2007 | 04:41 PM
staringback05's Avatar
+3 on the .100/.080....my friend Krisxpc is having issues right now with clearance with a ms4 cam...pretty sure his numbers are more liberal then those
Old Mar 11, 2007 | 05:15 PM
Tom@SpeedInc's Avatar
OR
Thanks
Why 115 ICL??? unless you have atleast 12:1 SCR don't see that working well?
In my 402 currently I have 236/242 .615/.612 113+5, peaks too early. I'd like to be around 110ICL, but changing cam for turbos.
Just my observation, 236/242 110LSA +0 would be good cam for a street driven 402/408.
