Question regarding Lobe sep/Intake centerline?
How would this cam compare HP/TQ wise to the same cam with 4 degree;s of advance ground into it?
Anyone?
JS
Suppose u never checked to see if the cam is in where its supposed to be and have a STOCK chain that has normal factory slop in it.
Most camshaft companies are adding at least 2 degree's into there camshafts on the LS1 for that reason.
So its possible it could be in 2 or maybe even 4 degree's retarded using a stock timing set?
I think this is absolutley possible....
JS
<small>[ September 10, 2002, 07:45 AM: Message edited by: JS ]</small>
Chirs B,Raugh,Fireball,PatrickG,JmX ???
Anyone?
JS
JS
<strong>Nothing Big,More or less I'm trying to get some info regarding cam timing and its effect on ET/MPH....
JS</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">JS, judging from your numbers I really doubt that your cam is degreed incorrectly. Where did your horsepower peak?
Surely u wouldnt think this isnt a smart idea since your already in the motor?
JS
This is and old school 350 with the only difference being the cam position.
Even though it's not a LS1, it shows what changes you can expect by moving a cam around.
Avg. through 4000 RPM
4* adv. - 0* - 4* ret.
TQ 379.4 - 373.2 - 369.0
HP 220.4 - 218.2 - 213.7
Avg. 4200 to 6250
TQ 369.4 - 371.4 - 371.4
HP 365.9 - 368.2 - 368.4
Average overall
TQ 374.4 - 373.2 - 369.0
HP 293.2 - 293.2 - 291.1
<small>[ September 12, 2002, 06:06 AM: Message edited by: Shaner ]</small>
Chris
I have a better "IRL chain"/KATECH oil pump sitting here at my shop an I figured since I'll have the car apart I might as well check the cam timing..
JS
<small>[ September 11, 2002, 12:11 PM: Message edited by: JS ]</small>
<strong>I'm not going into details about my cam timing until I check it frist.But I know the Comp chain thats in my car is the regualar one that uses the STOCK GM chain.
JS</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why will you have the engine apart? From your dyno numbers I doubt the cam/chain is screwed up
Chris
<strong>Say u have a cam with a 113LSA and it has no advance ground into it so its in at 113ICL if u put it in straight up?
Anyone?
JS</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Theoretically the cam should make the engine have more low end. Advancing the cam most of the time will cause the low rpms to gain power while taking it away from the upper rpm. One reason the LS1 has good low end grunt and high end HP along with emmissions is that we have a small duration cam with alot of lift (for stock) and cams that are put in retarded. Retarding a cam does the opposite of a advanced cam. The other thing is if you advance the cam and you gain high end hp it means you have to much duration.
That's a simple look at it.
Bret
<strong>Here's some numbers from a Comp Cam test.
This is and old scool 350 with the only difference being the cam position.
Avg. 4200 to 6250
Average overall
HP 293.2 - 293.2 - 291.1</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Shaner that would make sense to what I said above.
Good post.
