What would cause this to happen???
Old Sep 9, 2002 | 07:34 PM
99Z28RS's Avatar
Default What would cause this to happen???
My buddy's got a 89 5.0 and he rev it past 4000 rpm's, so its not able to peak out when he runs it, anyway just some suggestions if anyone has them, i know its not a Ls1 question be we cant pin the problem down, thanks
Old Sep 9, 2002 | 07:37 PM
Roadkill's Avatar
Default Re: What would cause this to happen???
What's the question? It won't rev past 4000? Check for clogged cats maybe
<small>[ September 09, 2002, 07:38 PM: Message edited by: Roadkill ]</small>
Old Sep 9, 2002 | 08:36 PM
99Z28RS's Avatar
What could be causing the car not to be able to rev past 4k? dirty injectors, not getting enough fuel mabey? i dunno
Old Sep 9, 2002 | 08:40 PM
H82BBad's Avatar
need a little more info
I had a stang do this it was all stock with a supercharger,regapped the plugs to .035 and it would rev to 6250
boost was blowing out the spark
<small>[ September 09, 2002, 08:41 PM: Message edited by: H82BBad ]</small>
Old Sep 9, 2002 | 08:47 PM
felton316's Avatar
Mine would not rev over 3500 when one of my fuel pumps lost power and the other had to push through it. Try checking the fuel filter. Also check the distributor timing, if its advanced or retarded too far it will fall on its face!
Old Sep 9, 2002 | 09:19 PM
99Z28RS's Avatar
Well he thinks that the previous owner put new plugs in but didnt gap em, im not sure all his mods but i know he has a filter,helix,headers, an accel coil pack, or something like that, and a cam mabey, dual flows and mabey a couple other small things, but i know he threw some lucas fuel injector cleaner in one day and he was able to get it in the 5400 rpm range and then it would start to act like a fouled plug or something, but that didnt last long hes back to 4000 again.
