TR220 or TR224 on a 114 center
Old Sep 9, 2002 | 10:21 PM
98_1LE's Avatar
Default TR220 or TR224 on a 114 center
What would the differences be? I want to pass inspection, so a 114 center is a must. How much rougher does the 224 idle, and does the 220 really sound stock? Thunder said that the 220 gives up ~10 peak hp to the 224, and shift point would be ~300 rpm lower (6300 vs. 6600). Does this all sound right? What are your experiences and suggestions?
The car is an '01 T/A M6 with normal bolt ons, and TTS long tubes with cats have been ordered.
Old Sep 9, 2002 | 10:29 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: TR220 or TR224 on a 114 center
Sounds about right.I run the 220 with FLPs and dyno at 370hp.It sounds very close to stock but revs freely to 6600.
Old Sep 9, 2002 | 10:34 PM
98_1LE's Avatar
Thanks
Would the 224 be any faster than the 220 shifting at 6200-6300?
Old Sep 10, 2002 | 01:04 AM
Slowhawk's Avatar
LS1Tech Sponsor
The 224 is a more powerful Cam.The difference is minimul.(maybe 8-10hp tops)I shift at 6400-6600.I personaly picked the 220 to make sure I can pass strict emission testing I have in Mass.
You could always install an underdrive pulley to make up the differences of the Cams <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 10, 2002 | 07:50 AM
Ragtop 99's Avatar
The TR 220 114 is a very good street cam. If you plan to shift at 6300, the 220 will meet your needs and not leave you wondering about emissions.
Gains from the 224 will be less than 10 HP. Comparable idle quality for the 224 can be achieved at 50 rpm higher than the idle used for the 220.
Old Sep 10, 2002 | 08:35 AM
98_1LE's Avatar
Thanks! I am going to stick with the TR220.
