claying for p/v clearance
couple questions.
1) Doing just the #1 cylinder intake valve will be enough right? No need to put on the other head and check the psg side at all (ie, if one lobe is good, they'll all be good)
2) does it matter what clay I use? I was gonna use my zaino claybar in the cylinder, rotate the crank 720 degrees, then cut it with a knife after it gets smashed and measure the cross section where the valve compressed it. Is this the proper method?
I just did cylinder 1 and made sure I put all of the surrounding bolts in. You may want to paritally tighten the bolts in the middle of the block by cylinder 3 a little as well, but it shouldn't matter.
My cam has a .581 lift on a 224/224 114LSA and I didn't even get a ding in the clay. Keep in mind that doing this by hand (I used a starter trigger to do it a lot faster) will not give you a measurement on the acceleration side where you may get some slight hesitation from the valve springs snapping shut. I'm not quite sure how close to measure the distance the valves come in that case.
Hope that helps.
