install question
Old Mar 10, 2007 | 08:30 PM
85ta383's Avatar
Default install question
just installed my heads and cam
mti stage 2e heads
longtubes
230/236 592/602 on a 114 +4 installed dot to dot.
all supporting mods and an ls1 intake till my ls6 gets here next week.
this thing is backfiring like crazy and wont hold an idle if i keep my foot on it @ 1000 rpm it runs and sounds great! i plan on getting it tuned this next week. will this go away?
is it normal.. everything sounds great no abnormal engine sounds. just some loud A backfires below 1000 rpms. i let it run today for a total of 20 min.
just want to make sure its ok.
Old Mar 10, 2007 | 08:38 PM
ShevrolayZ28's Avatar
mti stage 2e heads
longtubes
The same sort of thing happen when I fired mine up. Check the grounds on the back of the heads. Be careful not to cut yourself reaching back there lol.
Old Mar 10, 2007 | 08:42 PM
brad8266's Avatar
mti stage 2e heads
longtubes
i just got my 232/236 112LSA fired up and I had similiar issues. Are you using the stock injectors?
This might help ya.https://ls1tech.com/forums/pcm-diagnostics-tuning/673147-idle-tuning-ls1-edit-sorry-asking-i-searched-though.html
Old Mar 10, 2007 | 08:49 PM
85ta383's Avatar
thx man i figured it was a tuning issue.
thats pretty much what i needed.
my grounds are in and good!
ill get her up to the tuner next week and see where we are at on the tables.
yes stock injectors 28's from a 98
thx guys.
