Compression check
#1 150-175 #2 85-125
#3 125-175 #4 50-80
#5 105-180 #6 75-100
#7 125-150 #8 105-160
These are with oil. I'm not sure, but I wonder about the
head gasket between 4 & 6. Maybe leaking valves.
When these engines wear rings, do they do it evenly, or
can the numbers above be just a ring issue?
What do you guys think would be best for a car that weighs about 2400 lbs wet.
Here's how the car is setup now:
Ford 8.8 traction lock with 3.73 gears in it.
Stedda adjustable upper and solid lower control arms
LS1 from a 99 firebird
T56
No Cats, but stock (ls6 tri-y) exhaust.
True Duals 2 1/4"
X pipe
Bullet mufflers
The engine is so far back that the drive shaft is about 18" long.
I'm thinking about:
TEA stage 2 5.3
TR 230
I may not have room for full length headers so maybe stage 1 and a TR 220
Your thoughts please.
