Need cam specs
Old Mar 11, 2007 | 03:32 PM
09CPTN's Avatar
Default Need cam specs
Hey guys. I bought a used cam on here, but didn't get the card with it, and I forgot what the specs were. The comp cams site couldn't find the specs based on the numbers I gave it. Here's all the #'s I have from the side of the cam: XER281HR-12, 4D5405, and 2871 F. I would appreciate any help ya'll can give me. If I am missing a number or something, let me know. Thanks!
Old Mar 11, 2007 | 03:42 PM
JPH's Avatar
JPH
232/234 .595/.598 112+2 Xfi XE-R grind.
Old Mar 11, 2007 | 07:00 PM
09CPTN's Avatar
Thanks much!
Old Mar 12, 2007 | 12:33 PM
09CPTN's Avatar
One more quick question. The 112+2 effectively makes it a 114, which is what the guy told me it was when I bought it, but can I run it as either? Just not exactly sure how the XXX+X cams work as opposed to cams that are just the 112, 114, etc.
Old Mar 12, 2007 | 12:38 PM
DONAIMIAN's Avatar
112 is the lobe seperation and the +2 is the amount of advance. Two seperate things.
JPH's Avatar
JPH
112lsa, 110icl
the +2=2*of advance ground into the cam, which makes it have a 110 intake centerline.
Old Mar 12, 2007 | 01:32 PM
09CPTN's Avatar
Hmmmm, so this cam will probably be a bit more radical than I had previously anticipated.
