DYNO#S FOR 220/114 THUNDER CAM
Old Sep 12, 2002 | 05:47 PM
ARTY99z's Avatar
Default DYNO#S FOR 220/114 THUNDER CAM
Just curious what this cams potential is, also would like to know how the idle is. Thanks
Old Sep 12, 2002 | 10:38 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: DYNO#S FOR 220/114 THUNDER CAM
Idle is very close to stock at 800rpm.I gained 30rwhp from the cam.I had Longtubes installed before the Cam and on a M6.
Old Sep 14, 2002 | 04:21 PM
American Muscle's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ARTY99z:
<strong>Just curious what this cams potential is, also would like to know how the idle is. Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">From the dyno sheets that I have seen with this cam, people have been consistantly gaining between 30-35 rwhp.
How the cam sounds at idle, really depends on what exhaust setup you are running. If you are running LT headers through cats, and a mild catback like Corsa, or B&B Triflow, then the TR 220 114 LSA cam will sound fairly tame, with a very mild lope. However, if you are running LT headers, with cats, and a wide open Borla, or an SLP Loudmouth exhaust then you will be able to hear the cam more. If you remove your cats, then you will be able to hear the cam even more.
I actually have the TR 220/220 .561/.561 114 LSA cam sitting in my room right now, waiting to be installed this Wedsday. According to the Cam Pro Plus sheet that Thunderracing sent me, the final specs for my cam are 220.7/220.4 .553/.553 113.6 LSA. As you can see, my cam has a little bit bigger then advertised duration, and a lower then advertised LSA. Therefore this cam should have a noticable lope to it with the stock 800 RPM idle speed, and running through my SLP LT headers, HF cats, and my SLP LOUDmouth exhaust.
