Remove water pump with head swap?
Old Sep 14, 2002 | 07:50 AM
BB's Avatar
BB
Default Remove water pump with head swap?
Do I have to remove the water pump for a head swap if I am removing the freeze/drain plugs on the block to drain the fluid?
Thanks.
Old Sep 14, 2002 | 09:25 AM
jmX's Avatar
jmX
Default Re: Remove water pump with head swap?
No. Dont need to remove freeze plugs either if you dont want to.
Old Sep 14, 2002 | 06:47 PM
BB's Avatar
BB
Thanks to your write up on your web site I know that the two drain plugs don't need to be removed. However, based again on your write up, I want to avoid having to clean all the coolant from the head bolts holes and cylinders. I thought that would be more time consuming than removing the starter and the two drain plugs. I happen to be doing a clutch swap so getting the starter out was easy.
Since my clutch is still not here I think my heads may come in at the same time so I am doing both at the same time.
Old Sep 14, 2002 | 06:53 PM
Sears's Avatar
!Dial-up Director
Water pump stays on.
It really takes no time at all to remove the starter ( 2 bolts ) and the alternator ( 3bolts). Compressed air works real well for blowing out the holes, then go back and check for debris/coolant. I went back in every hole with cotton swaps just to make sure.
Justin
Old Sep 14, 2002 | 09:06 PM
BB's Avatar
BB
Jsears8 , did you drain the coolant from your block when you did your head swap?
Old Sep 14, 2002 | 09:51 PM
Sears's Avatar
!Dial-up Director
Yeah
Old Sep 14, 2002 | 09:55 PM
DERTY's Avatar
The Bull
The head bolts will need to be cleaned out regardless. The holes are blind and do not drain into the water jacket. Easiest way to clean out the holes is to take 1/2 sheet of paper towel and wrap it around a push rod. Ram them down the holes and the paper towel will wick the water out. Probably takes about 2 to 4 cleanings. I've got pictures of that method on my head cam install off my website.
Good luck!
Old Sep 14, 2002 | 11:03 PM
BB's Avatar
BB
Jsears8, do you know the size of the allen wrench needed for the tow drain plugs?
Thanks.
Old Sep 16, 2002 | 12:02 AM
BB's Avatar
BB
ttt
