How much will stiff Valve springs effect performance?
Old Sep 15, 2002 | 06:21 AM
KatfishRacing's Avatar
Default How much will stiff Valve springs effect performance?
A while back I found a great deal on some Agostino Stage 2 heads. The heads were set up for a stage two cam with the stiffer valve springs. The specs on the cam were 228/22/..560/560. I have installed these heads on my car, but I am only running a GM hotcam..218/228..525/525.
My question is: Is it worth it to swap to the springs that come with the hotcam kit? Any idea how much power the stiffer springs might be costing me?
Thanks, Mike
<small>[ September 15, 2002, 06:27 AM: Message edited by: KatfishRacing ]</small>
Old Sep 15, 2002 | 09:42 AM
wrencher's Avatar
wrencher
Default Re: How much will stiff Valve springs effect performance?
It's not the springs You would pick up alot more with that 228. Hot cam is ok but bet it is short-changing those heads.
