throttle position sensor
Old Mar 12, 2007 | 06:02 PM
iwantatransam's Avatar
Default throttle position sensor
This happened a couple times before, but is now happening more often. My 99 TA is completely stock except an air lid and a ripper shifter.
after driving a bit (20ish min) the idle climbs to 1200 and sometimes 1500.
My Traction control turns itself off, and I cant turn it back on
One time the "service Engine Soon" light popped on
Ok, I got a reading when the "service engine soon light" was on.
it said it was my throttle position sensor and my Idle sensor. how hard are they to fix? I can follow directions like a monkey, but if its a small chip in the middle of everything...well yeah I'm not that experienced.
Old Mar 12, 2007 | 10:24 PM
I'm guessing its pretty tough from the silence.
Old Mar 12, 2007 | 10:31 PM
DrkPhx's Avatar
You need to post the exact codes to get started. Second, you will have better response if posted in the PCM section.
