HELP! make my motor decision within>>>
ARE 360 (downfalls are: 7 hour drive to canada to get it and give them my core, 5 week wait, $1300 more)
however, since nu tek would be using my MTI C2 cam might as well add the cam price $400 to their estimate/ or sell the C2 and take the $400 off of the are price...
OR nu-tek in ohio (shorter drive) will be using my new MTI C2 cam here is the estimate:
Description Qty Amount
Clean block / including final wash 60.00 T
Hone LS1 block to 3.905 75.00 T
Deck plate hone - add'l charge 50.00 T
Align hone block 150.00 T
Deck aluminum V-8 block 125.00 T
Replace cam bearings 30.00 T
Balance assembly 225.00 T
File fit rings 60.00 T
Assemble full floating piston & rod assembly 45.00 T
Assemble short block 300.00 T
J.E. LS1 pistons 595.00 T
Manley LS1 rods 643.60 T
Ring set 179.00 T
3153KT Comp timing set 173.75 T
Crane hydraulic roller lifters 195.00 T
8-7100CH SBC large chamfer performance rod bearing set 45.28 T
LS1 performance main bearings 49.80 T
Cam bearings 25.99 T
12550574 LS1 Rear main seal 13.72 T
12558013 LS1 Front cover gasket 8.50 T
12561244 LS1 Crankshaft seal 9.05 T
12557840 LSI Bolt for balancer 3.33 T
12553210 LS1 Rear cover gasket 3.33 T
12558760 LS1 Oil pan gasket 26.01 T
ported LS6 oil pump
110.00 T
Thanks for considering us for your project
Sales Tax
(5.5%) $176.07
Total
$3,377.43
$3,377.43 plus my $400 mti c2 cam OR sell the c2 and do the ARE 360????
THANKS!!!!
will the few extra cubes of the 360 be a gain in HP?
<small>[ September 16, 2002, 08:34 PM: Message edited by: terry99ta ]</small>
MTI can rebuild a 346 with the best of em. hell, they are the best (when thinking of NA, hydraulic power). get a quote from them or go with Nu-Tek.
ALso, that "C2" cam is a COMP cam. COMP made those lobes. COMP. the C1 is also a COMP cam and TEA came up with that one. TEA. John just wants his name on the internet <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> just kidding John. that C2 crap was annoying.
I figured the 360 would be a few more HP than a regular 346 @ .005 over with a hone.
yes it's a comp cam, but mti calls it their C2 cam.
it's 224/224/ 581/581 114lsa will are be able to provide a better or as big a cam with the 360?
Trevor
