Fellow solid-roller guys
Old Sep 17, 2002 | 08:58 PM
GeorgeC's Avatar
Default Fellow solid-roller guys
What kind of valvelash are you running (hot)?
I haven't really experimented much, but have mine set at what I gather most folks consider kind of tight (~.020").
I'm thinking of loosening it up to .026" or so and see how the car responds.
Any comments?
Old Sep 17, 2002 | 10:03 PM
Futral's Avatar
Default Re: Fellow solid-roller guys
George,on my low-lash series the lash is .010"-.011" hot.On the race solid roller they are .024" hot.
The lash depends on the design of the lobe.
Old Sep 17, 2002 | 10:15 PM
Jason99T/A's Avatar
I can shift faster than you.
Just as Allan said, lash is determined by the type of lobes you are using, aluminium vs iron block/heads,etc.
I'd contact ARE and find out where they recommend setting it. Or just call Comp.
My old solid roller setup .009" cold (~.018 hot).
<small>[ September 17, 2002, 10:16 PM: Message edited by: Jason99T/A ]</small>
Old Sep 18, 2002 | 06:43 AM
GeorgeC's Avatar
I guess it would be helpful in my case to be able to refer to the cam card...
I'll see if I can get ahold of Wade @ ARE, and keep running the lash at .020 for now.
Old Sep 19, 2002 | 02:36 PM
One Monkey's Avatar
dido!! what the boys just said. It depends on your cam recommendations.
ours stuff is 16-18 for our street stuff.
Old Sep 19, 2002 | 05:23 PM
HP-GURU's Avatar
Fellow "solid roller" guys.
Sounds like a barrel chested group of men...,.
Old Sep 19, 2002 | 07:16 PM
703crewchief's Avatar
I would say they are definetly the guys pushing the envelope. My friend was told that he couldn't run a solid. Nobody would help him with suggestions on building a solid motor. "You'll beat the seats to death." "It will be too hard to program." "Nobody makes a valve or spring to work without heavy modification."
Old Sep 20, 2002 | 12:57 AM
C$'s Avatar
C$
One very important rule in dealing with solid cams is that too much lash can actually damage the valvetrain. I can't speak for every cam, but .026 seems pretty high.
