Piston Choice help
Old Mar 13, 2007 | 03:39 PM
Jbmoney21's Avatar
Default Piston Choice help
Im going with an aftermarket forged piston. Im looking for something that will keep my car at around 11.5:1. I am gonna run the Trex cam more than likely 242/248 .608 .612. Also have a set of 243 cast heads that have had port work and bigger valves that have been milled .030 so approximately at 59cc now. I want to know what kind of piston i will need to lower the chances of a PTV clearance issue. Want to stay stock bore or .010 at the max with stock rod length and crank.. If i get a piston with a -2cc relief will that be enough clearance. THats my main issue i want to stay with the higher comp and not have a PTV clearance
Old Mar 13, 2007 | 03:47 PM
xfactor_pitbulls's Avatar
-2cc will be fine for that setup. You dont need anymore than that.
Old Mar 13, 2007 | 03:56 PM
Jbmoney21's Avatar
Do u know if that will keep my compression ratio high enough
Old Mar 13, 2007 | 09:09 PM
Jbmoney21's Avatar
Need more opinions on this
