NOOB time..Rod bolts and mains
SAPPER
get it balanced?? i've never heard of that before ... i dont have katech's i picked up the top of the line arp
Ben T.
Ben T.
Some one had a comment that was like:
getting a forged bottom end for safety is like putting seat belts on the living room sofa
kinda makes sense. Thanks for the comments, that is the first I've heard of the resizing W/arps. How would you resize if this was the case?
Pretty much, if you aren't going to spray or put some kind of forced induction on there, you aren't gaining anything. I'd be too nervous doing something like swapping bearings with the engine in the car, like you said if the tolerances were off just a little bit its only a matter of time.
How do you resize? A shop grinds the rod caps to produce an oval shape on the big end of the rod and then uses a rod-resizing machine to make them round again- not something you do at home.
There are a lot of people who have upgraded bolts on this site with zero issues. The people who have experienced issues could be folks who failed to torque a rod or for some other reason erred on the installation.
Ben T.
Jason
. Jason, couldn't you mill the PM rod and cap and then resize?
