ls1 350 vs 346
Old Sep 18, 2002 | 03:10 PM
kewlbrz's Avatar
Default Re: ls1 350 vs 346
In general LS1 engines can be grouped accordingly:
All LS1 engine displacements are identical.
97-98
99-00 (valve cover bolt pattern changes on heads) also undocumented QA parts changes in LS1, different PCM programming, and smaller injectors, better overall engines then 97-98
01-03 LS1 gets 6.0 liter truck cam. (pre cats are used on the C5 for all 50 states) LS1 gets LS6 intake manifold, and LS6 clutch, LS6 cast iron exhaust manifolds, LS6 MAF sensor, and beginning in late 01 production (at least for C5's) the short block assembly is LS6 except for LS6 cam of course.
<small>[ September 18, 2002, 05:44 PM: Message edited by: kewlbrz ]</small>
Old Sep 18, 2002 | 05:26 PM
KOOSWS6's Avatar
Thanks for the feed back this answers alot of questions!
Old Sep 19, 2002 | 12:00 AM
KOOSWS6's Avatar
Default ls1 350 vs 346
I've been told the ls1 was changed in some way in '99 how and why was this done. I have a '98 ws6 m6 350 is this a inferior motor.
Old Sep 19, 2002 | 12:04 AM
FastAl's Avatar
The LS1 has always been a 346CI motor. Now it isn't uncommon for people to call it a 350.
Old Sep 19, 2002 | 12:14 AM
KOOSWS6's Avatar
My owners manual says 5.735L but the 346 is 5.665L I've checked NAPA online and they show a 350 and 346 engine options but only in '98.
Old Sep 19, 2002 | 12:23 AM
Colonel's Avatar
There is no such thing as a 350 CI LS1 from GM.
The LS1s all start life at 346 CI regardless of year.
Your '98 has a slightly different cam, pistons, intake manifold, and exhaust manifolds than an '02 LS1, for instance. It also has an EGR system which an '01-'02 does not (this is made posssible by the cam change.)
Stock for stock, an '02 makes more power than a '98. Maybe 20 HP more. Of course, it's easy to change a few parts to fix that. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<small>[ September 18, 2002, 12:24 PM: Message edited by: Colonel ]</small>
