Cam install questions
Old Sep 18, 2002 | 02:33 PM
cainsw's Avatar
Default Cam install questions
I'm about to install a cam this weekend and I've seen different post explaining step by step how to go about doing this and everything needed. But I did a search and now I can't find anything. So, do any of you guys know where I can find one of these post/sites? I'm kinda nervious about trying to do this by myself so I'll gladly listen to any advice. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I've changed several cams, but never on an LS1.
Chris
Old Sep 18, 2002 | 02:42 PM
98blackSS's Avatar
Default Re: Cam install questions
http://www.torquecentral.com/mods/GM...ll/default.asp
Some other good ones...
http://ls1.fbody.com/
<small>[ September 18, 2002, 02:43 PM: Message edited by: 98blackSS ]</small>
Old Sep 18, 2002 | 03:17 PM
SSINFUL's Avatar
One of the best suggestions I've heard is to take lotsa pictures (from all angles) before teardown.
Excellent for later reference...
This w/e? You got all the gaskets/bolts/tools already?
Old Sep 18, 2002 | 03:28 PM
DERTY's Avatar
The Bull
Take a deep breath and don't rush yourself. Keep your stuff organized and double/triple check every bolt! Pictures are on my website.
Old Sep 18, 2002 | 04:43 PM
98blackSS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by derty:
<strong>Take a deep breath and don't rush yourself. Keep your stuff organized and double/triple check every bolt! Pictures are on my website.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Best advice to give anyone doing a cam install for the first time. Give yourself plenty of time and take each step slowly.
Old Sep 18, 2002 | 06:40 PM
Superman's Avatar
Pretty straight forward.. obviously you`re techically inclined if you`ve changed cams before so it shouldn`t be a problem. I did mine on a Sat. no problems... Much easier than an LT1. Whenever I work on the car I get zip lock bags to keep bolts marked and seperated.
I didn`t get any manuals..
Good luck.
Old Sep 18, 2002 | 06:53 PM
sited12's Avatar
How long would it take for a first timer that only has seen web pages on it. No real experience.
Old Sep 18, 2002 | 09:42 PM
TA_2001's Avatar
couple of things..
get some pen magnets..
use them like this.
http://ls1info.com/article.php?sid=185
and dont forget to put a bit of
lock tite on the cam bolts for added security.
It took me most of the weekend but I took my time.
Old Sep 18, 2002 | 09:46 PM
highgmc's Avatar
http://www.sigma-epsilon.org/steve/install/headcam.htm
http://www.fbodylinks.com/tech/caminstall.htm
http://ls1.fbody.com/installs.html
http://ebramair.50megs.com/TransAm/HeadInstall1.html
http://xs-fx.com/raughammer/HeadsCam2/index.htm
some of my favorites...
Old Sep 19, 2002 | 03:22 AM
cainsw's Avatar
Thanks for the info guys! I ended up buy a Comp Cam from IRS. specs are the same as the TR224 224/224 .561/.561 112 What is the difference in these two cams?
