Break In For new Motor
drain any left over antifreeze and fill enignine and radiator with hot water,
fill the crankcase with 10 w 30 detergent oil, start engine and run for 25 to 30 minutes @ 2,500 rpm, occasionally pushing up to 3,000 rpm.
Shut off motor and let the car sit overnight,
then change oil, filter and refill antifreeze the next morning;
go to the track and hope that the rings have seated properly.
This is a track only car, so no chance to drive on the street. Any suggestions/ experience would be appreciated.
Thanks,
Chuck
Anyway, thanks again for the help.
Chuck
"The pressure takes the path of least resistance, which means it passes over the top of the ring, and gets behind it to force it outward against the cylinder wall."
If the pressure passed over the top of the ring and then behind it, it would force it outward, FROM THE WALL AGAINST THE PISTON. Wouldn't it?
<strong>What the hell does he mean by this sentence?
If the pressure passed over the top of the ring and then behind it, it would force it outward, FROM THE WALL AGAINST THE PISTON. Wouldn't it?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">no. when the piston reaches TDC the ring is seated on the bottom of the ring groove with some clearence on the top of the ring that will allow the pressure of combustion in behind the ring and force it outward against the cylinder wall as the piston assembly travals downward.
initially some gases might get by, but that is why you have two rings, both acting in similar fashion.
clear as mud now?? <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Chuck
Whats your opinion, you may have read my thread about this. I'm having my new ARE 436ci installed next week, the shop is 150 miles away. Should I drive it on the highway for its first 150 or trailer it home and do it in the city?
good luck with the new mill!!! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I have and know many others who have seized bike motors due to getting on it too soon. those are tight tolerances at first, heat = expansion!
can't believe everything on the net.
<strong>Any chance of them running her in on an engine dyno. This is the best way I know of. It can be cycled under controlled conditions over a preset program. Then just bolt her back in and away you go. Well worth it the extra cost .</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No engine dyno, but he has a regular dyno that he'll be using when everything gets installed.
