ls6 valve spring question
Old Mar 14, 2007 | 07:51 PM
FlyinGTP's Avatar
Default ls6 valve spring question
i tried doing a search for this but i seem to be having problems with the search tonight it keeps coming up with a blank page when it finishes no forum logos or anything. just says done down in the lower left corner of the spring.
Anyway my question is as follows. Can you still get BLUE ls6 valve springs the 01 specs and if so what is the part number.
i also have a question on pea green ls6 valve springs . i ordered these a while back in 04 for another car of mine. I was wondering if these are the same as the yellow ls6 valve springs.
neither of these sets of valve springs are going into an lsx based motor that is why i'm specificly looking for these springs.
Old Mar 14, 2007 | 08:39 PM
2xLS1's Avatar
01 LS6 spring part # 12565117.
I've seen the 02+ LS6 spring in pea green, yellow, and unpainted, all the same spring.
Old Mar 14, 2007 | 10:44 PM
GR33N GoblinM6's Avatar
what about the Orange Stripped springs?
Old Mar 15, 2007 | 07:33 AM
FlyinGTP's Avatar
thanks man
that was also what i hand thought about the pea green but wanted to double check on that.
as for the stripe i have seen yellowish stripes on some of the pea green ones is that what you are referring too.
Old Mar 15, 2007 | 12:41 PM
Vette1171's Avatar
Huh, that's new to me. I thought they were only yellow...mine were. Always learning...
