Preparation for MTI S2 heads/cam
Please offer your suggestions on preparation for stage 2 heads/cam for a street driven car. For example, should I go true dual exhaust, get an ls6 intake, beef up the tranny (manual of course), get a timing chain, etc....
I'd like to also know what went out after your h/c install so that I might purchase and install those parts ahead of time.
Thanks all.
Russ
camshaft with less than 224 intake duration
FLP longtubes with removable cats
3" cutout
quiet 3" catback like the SLP dual-dual
stock timing chain is okay
you will want a new clutch. Ram, Cartek, and McLeod Rev-Lok are all working well. Plan on a 12-bolt rearend if you want to drag race on slicks.
-Tony
Justin
Sounds like a clutch (mcleod) is probably in order and definitely a good short throw shifter to help keep away any mis-shifts.
I was thinking of maybe keeping the stock exhaust and adding cutouts for when I want to do the occassional all-out acceleration. Also planning on having MTI do the whole dyno tune to keep things in-line.
Any other tips or suggestions?
Thanks as always,
Russ
