How to break-in new LS1
My opinion? These engines don't require a majorly elaborate break-in. Just use good common sense. No WOT for a 100 miles or so. Then, no high RPMS (5000+) for another 400. After that, change the oil and drive it like you want to.
Again, the above are all opinions of mine.
don't hold a constant rpm for more than a couple minutes for the first 500 miles,
change the filter at 500 miles to catch any little pieces,
change the oil at 1500 miles.
i ran my car WOT twice on the test drive alone, and nothing changed after i got it home. car seems to run fine still with a little over 21,000 miles in a little over a year <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
-kris
Thanks.
<strong>You and I think alike. When I change it at 500 I'll be using dino oil again just to speed the break-in process. I'll change it over to synthetic at about 3000 miles. From there on out oil changes come about every 5000 miles. That's the biggest reason I run synthetic. I feel it's OK to go 5000 miles (or more) between oil changes and I don't feel comfortable doing that with dino oil. Either gets dirty but dino oil breaks down much quicker.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Two things, first of all the oil doesn't break down, the additives do. 2nd, How the hell do YOU rack up 5000 miles going 1/4 mile at a time??! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> hehehe I dunno about you but I've never seen a motor or ANY kind make 20,000 drag passes ;-)
What went wrong with the first engine? I have a 2002... bought it as a present for myself.... not happy. At 7 months, under 7000 miles, the engine was rebuilt for knocking. Dealer tore apart my whole front end, without consulting me first, ordered new psitons with tefelon skirts and re-bored the cylinders to match the new pistons. Rode ok for a bit now at 12,000 miles and ten months the knocking is back. Yes, it knocks when cold but also when hot if you listen carefully. Now GM tells me the knock is inherient to the engine and it will not hurt the car. So why tear apart a new car? I don't want a engine that was put back by hand rather than the assembly line with machines that don't forget to put in all the screws or not torque the screws to spec. Now GM is going to put in a long block on the car. Anyone else have knocking when cold? IS it really not a big thing or is GM just trying to make me go away?
Thanks for any help.
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
<strong>I've used Mobil 1 since new and no problems. Heck, that is what GM puts in them, so it must be OK.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">... uh... GM also puts in the 10 bolt, and the plastic interior, and they aren't OK at all <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Yes, the piston slap is somewhat inherent, ant sounds like that's what you have (quiets down as it warms up). Our engines can be built to NOT have piston slap, but that's not gonna happen at the dealer.
I'd say .... take the new long block & then don't let them touch it again, and just deal with it.
I declined having either the new rings (for oil consumption) or the pistons (or even a short or long block) put in because there is NO WAY I want those dealer buggers pulling my whole front end & engine apart!
I've had the piston slap since new, yes it's more pronounced now @ 60,000 miles & 10 road race days .... but it runs great (back at about 5,000 miles & before any mods it ran 13.299 on a slippery night).
It does use a moderate amount of oil (not as much as some, but more than is acceptable) ... on a track day I will use at least a quart in a total of about 80 miles of lapping.
<small>[ September 30, 2002, 05:58 PM: Message edited by: M3EATER ]</small>
But during those 500 use every different throttle position. Just don't go WOT for more than 2-3 seconds. On the highway change from D to OD, don't stay at one set rpm for more than 5 minutes.
Then ring that bitch out <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
<strong>i left the dealer ship sideways.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto....AND she's still running good...even with Mr.NX under the hood.
<strong>I've also noticed that the more stout cars have been beaten on from the get go...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe this too. I beat the snot out of mine right from day one. With 50 miles on the clock I had my first highway race, and redlined it in 4th gear beating up on a Mustang. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Then a week later with 700 miles on it, I made 16 quarter mile runs. People to this day are still impressed that my 98 Formula ran 12.68 at 110.6 with just the following mods:
4.10s and drag radials
ported stock MAF
MTI airbox
HPP3 programming
cutout
