382 Stroker VS. 382 All bore?????
So for my setup (M6, N2O, 4:10s heads/cam) it seems that the all bore is the way to go..
Keep the info coming <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
4.1 x 3.62 = 6630 RPM
3.9 x 4.0 = 6000 RPM
A long stroke moves power down in the rpm range with a small amout of HP gain but a larger gain in torque. This sounds good, but I would rather have a broader powerband that is more tractable because it gives away a little on the bottom and makes it up in the upper end of the powerband. Also a long stoke is not as forgiving on over rev just because the piston speed is multiplied even further.
I cam to the final conclusion,
Big Bore: good peak rwhp @ about 6300. riving the engine very high = more friction and faster wear and tare. Also, big bore has no forged internals. Thinner sleeves might break, might have high temps, and the biggest problem it the sleeve shifting issue. Ruff idle, well, depending on cam. But cheaper!
Stroker: good peak rwhp @ about 6000. Lower engine rpm = less friction and longer engine life. Better TQ. Also, stroker engines have forged internals which are a plus for more durability and additional power, NOS for example. Stock sleeves, therefore, no temp issues from sleeve thinness and should handle power better. But a bit expensive.
All in all, I think the Big Bore rwhp peaks about 5 rwhp more at around 6300. But a stroker will peak lower @ around 6000 with more rwhp (will get to power sooner).
I went with the stroker! I got 450 rwhp and 446 rwtq. I could see more power with a bigger cam very easily. But, drivability is very important for me. Also, with my new 200 hp MAF plate NX shot (getting installed soon), no all bore can catch up! <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> Just kidding!
<small>[ October 01, 2002, 05:22 PM: Message edited by: RUF SS ]</small>
Im still undecided. Im thinking about spraying a direct port 200 shot, probably progressive, too.
decisions, decisions.....
<strong>
Stroker: good peak rwhp @ about 6000. Lower engine rpm = less friction and longer engine life. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I disagree. The stroker while it might not rev quite as high as an all bore, the difference in minscule relative to wear, but sideloading is an issue. Moreover, as has allready been mentioned a stroker has more movement of rod/piston per equal amount of movement in an all-bore. So the wear and tear is actually heavily weighted on the stroker. Not the all-bore.
How would this perform? I would like to shoot a good sized shot of nitrous like a 150 or 200 shot. Would a forged 382 all bore be able to handle it?
<strong>kewlbrz, torque is what gets you down the 1/4 mile, not hp. I would rather have 500 tq and 450 hp over 500hp and 450tq anyday of the week.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That would strictly depend on set up.
<strong>kewlbrz, torque is what gets you down the 1/4 mile, not hp. I would rather have 500 tq and 450 hp over 500hp and 450tq anyday of the week.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Oh dear, here we go again. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by kewlbrz:
You should quantify that, since HP is a function of TQ. They should not be compared directly. TQ all by itself is meaningless and does no work without movement (RPM), which = HP.
Bottom line is bore over stroke, when displacement is similar, the bored motor will dominate in a drag race.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What would be better for drag racing?
everything else equal:
500 RWHP 460 RWTQ
460 RWHP 500 RWTQ
FaSS Blac,
A NASCAR motor is also a pile of junk after a race and they idle horrible, not a good comparison to the street cars we got goin on.
Same with a 950 HP CART motor, there amazing but totally useless on the street. Not to mention methane gas.[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The Torquer. That engine will win at the strip due to lower ET rather than high MPH
Bret
Cubes are Cubes, the longer stroke and smaller bore mean, smaller valves to go into the engine and shorter rods. Both of those are not pro-HP mods IMHO.
Bret
[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So more TQ and less HP is better for the drag race?
valve train efficencies.
Lower diff gears (on street that means lower revs at hwy speeds = better fuel economy and engine wear.
Less tq converter is needed...most likely means better everyday driver.
All in all my preference is which ever is cheapest.
I personally want big bore and offset ground stock crank, but I may change my mind <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
IHRA Pro Stock motors have huge strokes on them and lower diff gears, make mountains of tq (and hp) they seem to go as big as they can no matter how it gets that big.
<small>[ October 04, 2002, 05:10 AM: Message edited by: v8 ute ]</small>
