lots of smoke comin outta the back of the car....
Only occurs after the car has run for a while (seems over 2 hours) and at high speeds (seems to be over 100mph). Several people have suggested it may be PCV blowby problem... but I dunno...
Havne't done a compression check yet
What do you think it could be? I'm planning on replacing the ENTIRE top end (only stock parts should be block, crank, rods, pistons, and maybe a few parts I don't know about) this winter... but this smoke is pissing me off...
it's only happened on 2 occasions, but once it starts, every time I get on the gas at high MPH it does it again... and you can see it out the rear view mirror.
thanks
Edit: Smoke appears white from inside the car.... but at the speeds it occurs i'm paying more attention to the front than the back.
Is it possible to have a VERY small crack in hte head gasket, and it only is opening up enough to let coolant through at high speeds (high combustion chamber pressures)
<small>[ September 27, 2002, 11:41 PM: Message edited by: horist ]</small>
<strong>When it smokes after you give it gas was it closed throttle no gas? Do you have a spark knock issue at hi-speed? High milage motor, the stock pistons leave alot to be desired.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">well... not sure about the spark knock issue, not sure what that means.
It has occured both under gas and when I let off... today at the drag strip it happened when I let off.
I was getting 3-5 degrees of KR up top today... and my mph is way down.
Motor has about 40,000 miles on it
I think my valve train is pretty tired ... when I first got the car I knew nothing about cars and figured a mere 600 RPM was nothing... so I was shifting at 6600 RPM (hpp3) for about 75 runs....
I'm planning a top end rebuild this winter.... hopefully the bottom end is ok (no weird noises, no rod knock....)
