LS6 block in 01/02 F-Bods?
Can you guys help me answer these questions?
Someone also made the suggestion that the 01/02 F-bodies(and LS1 Vettes I suppose) come with LS6 blocks! Is this true?
Thanks for the info guys,
Mike
Also the LS6 block is a somewhat stronger made block.
The LS6 block began being used in late 2001 C5 production (I dont if it was used in f-body production or when).
Here is a pic of the window in the LS6 Block:
<img src="http://www.vetteguru.com/misc/window.jpg" alt=" - " />
And here is a pic (litmus test) to tell if your "LS1" uses the LS6 block. Look at the extension of the block deck on the right (passenger) side just forward of the head (where older small block motors had the serial number stamped). You will see a rough indentation toward the center of the block and a flat machined section toward the side of the car. On the LS1 the machined section is flat and on the LS6 the machined section has a slight machined cutout.
<img src="http://www.vetteguru.com/misc/2001_ls1.jpg" alt=" - " />
Remember folks, the LS-6 block doesnt mean LS-6 pistons, LS6 PCV, or LS6 heads.
chris
<strong>actually, as far as strnegth of block, most resleeving vendors want to do it with a 99-00 LS1 block, since they have better sleeve support. The LS6 blocks in '02 are recommended for road racing with their better oil passages and a few minor bennies, if you dont resleeve it large.
chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am fairly certain that the pistons are shared among model years Since the LS6 gets it compession increase from a smaller chamber, and not the piston.
