Used camshaft.
Old Sep 29, 2002 | 09:31 AM
Ackattack's Avatar
Default Used camshaft.
I was wondering if you could put a used camshaft in and be ok, or will the wear from a different car cause it not to work good in my car.
Old Sep 29, 2002 | 03:11 PM
SSINFUL's Avatar
Default Re: Used camshaft.
The components used w/ any cam can have an affect on how well the cam transitions to being reused: The most obvious signs are visible wear or discoloring.
I've sold my old cams w/out incident.
Old Sep 29, 2002 | 03:15 PM
gator's 99TA's Avatar
derek you are looking for a used cam? give me a call or email me, i might have something for ya i will hook a KS bro up! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
also to answer your question with roller (mostly) camshafts of today the lifters do not put much wear at all on the lobes. BUT i would always be nervious to buy someones used cam as you dont know what you are getting. it is STILL a risk in buying something as important as a camshaft that is a wearable item. i would not buy a higher milage cam, but that is just me personally.
<small>[ September 29, 2002, 03:19 PM: Message edited by: gator's 99TA ]</small>
Old Sep 30, 2002 | 12:12 AM
RaNsOm's Avatar
you should be fine, people sell used cams all the time. I'm buying one from my buddy in a week or two. Nobody has ever said that you cant use used cams
