Two questions specifically about 98 LS1s
I have some basic bolt ons:
Stainless Works Headers with 2.5" Y pipe
TR224 112 LSA cam
LS6 intake
918 springs
TR hardenend pushrods
Taylor 10.4 mm wires
ASP pulley
B&B Triflo exhaust
QTP cutout
NGK TR55IX plugs
LS6 ported oil pump
Katech timing chain
BMR LCA's
SLP SFC's
UMI double adjustable dual rod ended PHB
Spohn adjustable body mounted torque arm with longer bolts
uh....and yeah....Direct flow lid
....all of which I just did coz I wanted it to sound mean, and so I can put something in my signature....
ANYWAYS:
I heard that the 98 cars have weaker rod bolts. When exactly does that come into play? Only when you drive the car hard and rev it high, or is it a factor just because the car makes more power now?
Also, I do want to get heads now....probably the PRC Stage 2.5 from Texas Speed, but if I rememeber correctly, the 98 cars have a different head bolt pattern than the 99 and up, and new heads all use the 99 and up pattern, right? Would I have to just order a new stock 99+ valve cover then, and is the dealer the only place to get those?
Thanks!
Manny
Yes, you would need to grab some center-bolt valve covers and coil pack brackets. You can get the brackets from the dealer for cheap, and the valve covers from a wrecked car/ this board/ other /etc. Those should be easy to find.
Ben Theriot.
there is a thread on this site for the spun rod bearing club.. i think if you regularly spin your motor to high rpm's....98 or any other year.... you can pretty much count on rod bolt failure.
so if your gonna see past 6600 regularly change em out. if your just a "recreational driver" i think you will be fine.
my 98 has 88000 on it, still in one piece!!
